Author Topic: Clutch problem - not much friction zone  (Read 1949 times)
Offline jkot55
  • Wingman55
« on: February 28, 2010, 07:33:42 AM »
On CB750K5 (1975)  no friction zone.  The clutch does not grab until nearly all the way out.  Should occur about half-way.  Does anyone know what that is a symptom of?  It does not slip once fully engaged.  It just affects ability to control at slow speeds and makes it harder to coordinate engine speed with clutch engagement from a stop.  More of an annoyance but before I tear it appart to see what needs replacing just wanted to get your ideas first.
Thank you
When I ride my CB750 I'm a teenager again
Offline mystic_1
  • 1970 CB750K
Re: Clutch problem - not much friction zone
« Reply #1 on: February 28, 2010, 07:58:54 AM »
Have you done a full clutch adjustment?  Loosen both cable adjusters, adjust the lifter, then lower cable adjuster, then the adjuster at the lever.
mystic_1
- John Augustus Shedd
Offline dhall57
« Reply #2 on: February 28, 2010, 10:11:56 AM »
I know what you mean jkot55. I have a 76 CB750 with 17000 miles with same situation. I have a 97 HD Wide Glide also and the clutch takes hold much sooner than on my Honda. Ive adjusted my clutch per this forum specs. and clutch still doesn't take hold until almost end of release, but bike shifts fine and clutch does not slip. Someone correct if Im wrong , but I think this is more a characteristic trait of most CB750's. If your clutch is not slipping and its adjusted correctly I think your fine. Its just a little awkward getting use to it.
dhall
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #3 on: February 28, 2010, 10:27:39 AM »
Here's one link to the cure:
http://forums.sohc4.net/index.php?topic=7401.msg67256#msg67256
Another link is my book, in the "Reassembly" chapter, on how to fix the clutch for good! I have a lot of detail on it in there.
Offline jkot55
  • Wingman55
« Reply #4 on: March 01, 2010, 07:52:08 AM »
Guys, thanks for the tips.  mystic_1; I'll give that adjustment a try.  Since owning the bike I have not looked at the adjustment other then the lever on the handlebars.
Hondaman:  Just bought your book.  I figured I love my CB750 enough that it is well worth the investment.  I hope you sell a lot of these.  Thank you for taking the time to share.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: March 01, 2010, 08:19:45 AM »
Yup, definitely adjust the clutch before doing anything more drastic.
See below.
mystic_1
