Author Topic: how to remove stuck jugs?  (Read 1603 times)
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« on: March 01, 2010, 07:09:36 PM »
Hey folks--yes, I searched the topic, and didn't come up with anything too helpful...  The motor was a running CB400f with only 5800 miles.  pistons move freely in the cylinders and the heads came off fine.  I've sprayed pb blaster down the cylinder studs and around the base gasket.  I've tapped every so gently around the fins with a mallet.  Doesn't seem to want to budge...
Any other tricks out there?  Thanks!
Offline faux fiddy
  • bike in a box
Re: how to remove stuck jugs?
« Reply #1 on: March 01, 2010, 07:15:36 PM »
Don't smack on the head, put a soft wood 2x4 block against it and give it a couple firmer whacks sideways and upwards.
Make sure again that every fastener is out and rock back and forth in gear a bit. Try to slip a thin putty  knife between..
It's wanting to come apart..
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: March 02, 2010, 03:56:46 PM »
You can also get a nylon "body pry" to work in under the block to help break the adhesion of the base gasket
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Online Alan F.
« Reply #3 on: March 02, 2010, 04:33:44 PM »
I wouldn't pry too hard, I recommend warming the block gently with a propane torch between the fins. Keep the torch moving and shoot for something close to operating temperature. Every now and then rotate the crank, the piston movement should be enough to loosen the jugs without prying much if at all.
-A
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #4 on: March 02, 2010, 04:56:11 PM »
i saw the topic and my dirty mind kicked into overdrive.  :P
Mark Twain - Notebook, 1894
wdhewson
« Reply #5 on: March 02, 2010, 05:48:51 PM »
I've become a real fan of the application of heat.
Heat tends to eventually soften everything and cause the adhesive materials to lose strength.  Especially if those adhesive material are just junk and dirt.
Bring it up to hot with a liberal torch played eveny around the cylinder base and crankcase top.
« Last Edit: March 03, 2010, 01:16:10 PM by wdhewson »
Online Alan F.
« Reply #6 on: March 02, 2010, 06:20:27 PM »
Me too Jeff, Heh heh.
Offline jessezm
« Reply #7 on: March 03, 2010, 06:16:32 PM »
Victory is mine!!!  I used a heat gun and got the cans nice and warm, then a few hard taps with a mallet and she came right apart.  I can't believe how clean this pistons are!  aside from some minor deposits on the top, they look brand-spankin new.  Somebody babied this motor for the 5800 miles they put on it.
Thanks for all your advice!
Offline faux fiddy
  • bike in a box
« Reply #8 on: March 03, 2010, 06:46:45 PM »
yea!
Online Alan F.
« Reply #9 on: March 03, 2010, 07:34:43 PM »
good work!
Offline fasturd
« Reply #10 on: March 09, 2010, 01:36:05 PM »
So its to late to say ...
"Buy her a couple of martinis?"
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
