thanks, that helps
If you can slide a putty knife or something thin in between the lower crankcase and the barrels, and do this all the way around the gasket, then it should only be a matter of wriggle wriggle wriggle to remove it....
stand with legs over the engine (I presume it is on the floor), and with one hand at each end of the barrels lift alternately from left to right & back to front, there should be some movement after doing this if all studs & bolts have been removed. There isn't anything else to undo...
When it does start to lift up, be careful, if you have a broken ring it could fall into the crankcase.
Its then just a matter of continuing this processs until the barrels come off.
When the barrels are up abount an inch or so,,, pack a clean cloth around the conrods and cover all open areas, just in case anything else drops out...
Don't strain and break a gonad either............
have another beer, probably a bit of sweat to go...
