Author Topic: clutch arm....help  (Read 519 times)
slapi01
clutch arm....help
« on: March 05, 2010, 09:52:05 AM »
is the spring suppose to be under the clutch pivot arm or does the end of the spring go on top of the arm when in place. i was in the process of putting on my clutch cable and having a hard time with it. cable seems really long, but it's the same size as the one i was given(not mounted) i read up on routing playing a big part, but for the life of me can't figure it out.. anyone got cb350f clutch cable/adjuster pics
slapi01
Re: clutch arm....help
« Reply #1 on: March 06, 2010, 06:22:43 AM »
bump for help
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #2 on: March 06, 2010, 06:45:40 AM »
76cb550:  similar clutch (identical to your pic), arm goes under spring.
bobp
searching for a dr350se
