I already had the switch off to put the low 400F handlebar on it and I didn't see any empty connectors.
I think the way Honda did it was to use identical wiring harnesses and wiring on the UK and US bikes, except the UK bikes had a switch in the path of the headlight current, while the US bikes would have a straight wire running in the same place. This would allow them to use the same parts for both market's bikes, but only use different switchgear. From an economic standpoint, that makes sense. No need for completely different electrical systems for the two different markets.
Such a design would save Honda $$$ and make my job a lot easier. Straight swap. If they went the different (hard) way and wired the bikes different, then I'm screwed unless I want to re-engineer my bike. If that's the case, I will do a hidden switch in the bike as opposed to re-engineer the electrics, even though it's probably something simple as replacing the wiring harness and switches with UK-spec ones.
A lot of manufacturers do stuff like that: pre-wire the car for the good sound system and if you get a car with the base radio, you still have the hard parts prepositioned to drop in the good factory parts later if you wish. Cheaper to build them all the same way, then put in different end-items, versus building them two completely different ways.
