Author Topic: MAC 4-1: Took baffle out now WAY too loud. Easy glass pack fix?  (Read 9712 times)
Offline Gorms
  • Barkeep! Give me a beer and a
I took the "baffle" out of my MAC 4-1 on my cb550.  Looks like this:
Now the bike sounds great but its WAY too lou and I think I would get pulled over.  I would like to use something else like a perforated pipe wrapped in fiberglass but I'm cheap and dont want to buy something expensive.  I could cut out the two pipes on the original baffle and replace it with a perforated pipe but I dont want to destroy it just yet and I dont own a welder.  Is there an easy, cheap, homemade solution here?
Offline ANVkevin
  • CB750K7
Re: MAC 4-1: Took baffle out now WAY too loud. Easy glass pack fix?
« Reply #1 on: March 09, 2010, 08:06:00 AM »
Ear plugs? ;D
I'm about to go through the same issue. I think I might just end up building a new set of baffles and hope for the best. Hopefully someone can chime in with a proper answer.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: March 09, 2010, 09:30:33 AM »
get you some good stainless steel wool to re-pack it. a nice heavy gauge one.
Mark Twain - Notebook, 1894
Offline laser145
  • underfunded
« Reply #3 on: March 09, 2010, 09:35:45 AM »
How do you keep the steel wool from blowing out?
Offline Steve F
« Reply #4 on: March 09, 2010, 09:40:39 AM »
You can't.  The stuff vibrates and breaks up and blows out.  Also, the problem with your current baffle is it can't be packed in any way because of the way the exhaust gasses are routed.  If you want to make a "glass pack", you need a perforated straight tube that goes from one end to the other and is wrapped in fiberglass. The stuff Kerker uses is REALLY coarse fiberglass, not at all like you use for house insulation.
Offline domer
« Reply #5 on: March 09, 2010, 09:53:26 AM »
http://www.crc2onlinecatalog.com/baffles.htm
i think the kerker one they make might work, but dont quote me... but the have the fiberglass for 8 bucks... just an idea.
Offline bucky katt
    • facebook
« Reply #6 on: March 09, 2010, 10:07:42 AM »
i have a stainless steel supertrapp muffler that would probably work out okay for you. pm me if interested for pics.
Offline jeremy929
« Reply #7 on: March 09, 2010, 03:45:09 PM »
This was my solution. Its metal gutter guard rivited to the mac endcap and some dirtbike muffler packing. And this
72 cb500  , 78 cx500
« Reply #8 on: March 09, 2010, 08:19:38 PM »
Be careful with regular steel,steel wool. The stuff believe it or not is very flammable,especially the finer grade 00 - 0000 material. Light some and try it.
Offline Gorms
« Reply #9 on: March 09, 2010, 08:42:10 PM »
Thanks. This was the type of solution I was looking for.  How does it sound/perform?  I dont want to regret cutting up my stock baffle...
Offline Kframe
  • Life is good!
« Reply #10 on: March 09, 2010, 09:36:58 PM »
I wonder if that brillo pad type material would do better?  Or burn up less at any rate.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #11 on: March 09, 2010, 10:49:12 PM »
i've made cheap baffles for the mac can by cutting the middle section out of the stock baffle, leaving about 1.5" sticking inward in either direction. connect the middle with perf sheet metal wrapped around the two solid tubes, secure with hose clamps, wrap with fiberglass (i've used both wall insulation and the stuff sold for wrapping HW heaters, as well as the stuff sold for mufflers), and reinstall. takes about 30 minutes to make, and sounds great.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline jeremy929
« Reply #12 on: March 10, 2010, 04:04:33 AM »
I like the sound, its not to loud. On the performance side feels faster, probably does little to nothing, but you know its louder so it has to be faster  ;D. I dont regret cutting it up at all the stock mac sounded awful to me.
72 cb500  , 78 cx500
Offline KeithB
« Reply #13 on: March 10, 2010, 07:09:10 AM »
That is the "mechanical" baffle and doesn't sound that good.
MAC makes a different style of baffle that will fit and uses fiber glass or something of that sort.
Installed one on the 'CB 750 and it sounds great!
Nanahan Man
Offline Gorms
« Reply #14 on: March 10, 2010, 09:46:13 AM »
Thanks all, I am going to cut up the stock baffle and make what a couple have suggested.  My only worry is that both end flanges on my stock baffle fit very snug inside the muffler and I'm afraid the perforated metal tube will collapse when I install or have to remove the baffle.  I had to knock the baffle out very hard with a broom handle through the front end of the muffler.  Do you think I should even use the inside flange at all and just make what jeremy929 pictured above or what paulages suggested?
Offline bender01
« Reply #15 on: March 10, 2010, 10:00:04 AM »
I seperated my mac baffle and stuffed a kitchen sink strainer in the pipe first. Wrapped the remaing outer baffle with stainless steel scrubbies and reinstalled. It was snug so the strainer wouldnt wiggle free. It was on a 350f and sounded so much better.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline domer
« Reply #16 on: March 10, 2010, 10:07:20 AM »
why not take that stock baffle and a 1/4" drill bit and swiss cheese the m.f.? if your gonna hack it up anyway it might be worth a shot... ive seen baffles made of swiss cheesed 1 1/4" pipe that didnt sound bad.
Offline cb650
« Reply #17 on: March 10, 2010, 11:07:20 AM »
Thats what I did to my oldest mac.
Offline paulages
  • 1976 cb735
« Reply #18 on: March 10, 2010, 01:09:31 PM »
Unless the perf sheet you use is really thin, you won't have a problem with it collapsing. I've made lots of baffles this way and have never had a problem. Of course, once I had the set screw vibrate loose on my BSA, and the entire baffle shot out on the freeway somewhere.
The stock baffle requires the exhaust gas to enter, fill the can, and exit through the second tube. A glass-packed straight through design will flow much more freely. The amount of baffling depends on the ratio of open area in the baffle tube and the amount of packing. Mine is 1.5" I.D. straight through, and is actually pretty quiet at idle. Sounds #$%*ing great at 9K RPM though.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
HondaDano
« Reply #19 on: March 10, 2010, 07:30:00 PM »
I made mine from an old oil filter. Cut the filter in half about 1/2" from thread on side, pull 6" perforated tube from center of filter, and weld it to the center of the old threaded filter side. I don't know what a stock Mac baffle sounds like because mine didn't have no baffle when I got it but I think this sounds pretty good. It's way to damn loud just open without a baffle. It's a inexpensive trick to try especially if you've got old filters laying around. I can't remember what make the filter came from but it's about 4" diameter. Dano
