Author Topic: Architectural History  (Read 593 times)
Offline Caaveman82
  • Zippo
  • That'll do pig. That'll do.
« on: March 11, 2010, 09:02:21 AM »
I have an architectural history class this semister that has really grabbed me. This stuff is new to me but one building that really caught my attention was the Basicilica di Santa Maria del Fiore, also known as the Florence Cathedral. There are many reasons I enjoy it. First of all it marks the begining of the renaissance era, which only lasted about 50 years before you get into high renaissance, late renaissance, which then gives way to the baroque which was pretty much the exact oppisite of renaissance.
The dome at Florence Cathedral was designed by a guy named Filippo Brunelleschi around 1420. He had won a contest that the merchants of the city had been holding. In these days the merchant class ran the show the government was bought and sold by these people untill eventually they realized they had the power and pretty much made the government obsolete. Any way, Brunelleschi was a gold smith in the beginning and had previously entered a contest and lost. So being the emo kid he was he took off for Rome to spend quite a few years refining his studies and really taking a deep look at ancient Roman architecture, like the Pantheon and Colosseum. When he returned he had entered the contest for the dome and narrowly won it.
His idea was to put a dome within a dome, which untill this point had never been done, it was also to be the largest masonry dome to date. His idea was to use marble rib vaulting at every 90 degree angle and then make the outer dome out of brick and the inner dome out of concrete with five giant chains to reinforce it. The first time concrete had ever been reinforced. So for the outter dome he used a method of brick laying called harring bone, which up till that point had always been for looks but was never considered to be a method for structural support. Four million bricks went into the 140' dome.
Brunelleschi also pioneered many other things while working on the dome. He designed a lift that you could hook an oxen up to and it could just travel in one direction but there was a mechanical way to choose between lowering or raising instead of having to take the ox off and turning it around to make it go the other way. He also invented a lift that boomed out and not just up. Then he put a cantena up in the rafters for the workers so they would not have to waste an hour a day climbing up and down just for lunch. Maybe that's where the roach coach idea comes from. Other than that he was also mostly responsible for rediscovering the single point prespective and utilizing it when it came to architecture which then laid the ground work for the blue print.
All and all it was an exciting time of change and the thing that made it really interesting is that for the first time in history a vast majority of people KNEW they were living in an exciting time of change. That is my opinion at least.
[img width= height=]http://www.ucalgary.ca/applied_history/tutor/imagemid/florencedome.JPG[/img]
Offline BeSeeingYou
Re: Architectural History
« Reply #1 on: March 11, 2010, 09:27:58 AM »
While not nearly as ancient or significant check out the history of the Metropolitan Building close to home here in Minneapolis.  Considered to be one of the most architecturally significant buildings in the history of Minneapolis.  Built in 1890 and torn down in 1961 in the cause of "urban renewal".  An act of architectural vandalism that people here still howl about.  Built before the age of electrical lighting it had an large central skylight and glass floors surrounding the atrium to let in light.
« Last Edit: March 11, 2010, 10:01:04 AM by srust58 »
Offline Caaveman82
  • Zippo
« Reply #2 on: March 11, 2010, 09:31:04 AM »
While not nearly as ancient or significant check out the history of the Metropolitan Building close to home here in Minneapolis.  Considered to be one of the most architecturally significant buildings in the history of Minneapolis.  Built in 1890 and torn down in 1961 in the cause of "urban renewal".  An act of architectural vandalism that people here still howl about.  Built before the age of electrical lighting it had an large central skylight and glass floors surrounding the atrium to let it light.
That is super cool I will have to do some more research.
I have to do a big presentation at the end of the semister on the Walker Art Center expansion, should be interesting.
Offline tramp
« Reply #3 on: March 12, 2010, 03:49:49 PM »
when you think of what they had to build with
it is amazing
1974 750k
Offline Brown Bomber
« Reply #4 on: March 12, 2010, 04:26:54 PM »
Cincinnati is home to a lot of great Art Deco buildings. Union Terminal is one of my favorites.
The tile murals are very impressive.
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
