Author Topic: '78 750F 1st gear problem  (Read 1463 times)
Offline killerdwarf
« on: March 11, 2010, 04:19:47 PM »
I just recently picked up a '78 750F in pretty nice shape. Cleaned her all up, cleaned out the carbs, and fired her up. Runs real nice!!! It's not so good for first gear though. It doesn't seem to engage properly, like it's only going halfway in. As soon as you let the clutch out, it jumps right out of gear,and knocks. A lot of times, when you do put it into first, the neutral light flickers, until you stab the shifter to try to engage the gear more firmly. It's acting like a bent shift fork, but I have never seen that happen for first? Is there any common problem within the selector mechanism I should look for?
Re: '78 750F 1st gear problem
« Reply #1 on: March 11, 2010, 04:48:16 PM »
Welcome to the forum!
Most likely the problem is, indeed, in the selector. Sounds like the shift drum isn't rotating far enough; that's why the neutral light flickers. My best guess would be a broken spring on the thingy that hooks onto the drum pins and turns the drum.
Offline Freaky1
« Reply #2 on: March 11, 2010, 04:49:53 PM »
I hate it when the thingy need to be fixed!  ;D ;D ;D
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
« Reply #3 on: March 11, 2010, 04:51:01 PM »
ME TOO!! :D
Offline killerdwarf
« Reply #4 on: March 11, 2010, 05:47:08 PM »
Thanks. I pull it apart again and have a real close look at it. When I had it apart earlier, I didn't find anything broken, or bent. All the other gears work fine by the way.
« Reply #5 on: March 11, 2010, 06:30:42 PM »
That's not the thingy,technically its the Doohickey  ;D
« Reply #6 on: March 11, 2010, 06:32:59 PM »
OK, that's the 2nd time tonite you guys made me really LOL!!!
Offline killerdwarf
« Reply #7 on: March 11, 2010, 06:44:14 PM »
I come to my thread for answers, and get this crap?
« Reply #8 on: March 11, 2010, 06:49:11 PM »
Hey man, sorry. My first post was my answer, but I did get a belly laugh out of the "crap".
Scott
« Reply #9 on: March 11, 2010, 07:23:50 PM »
Just for the record, IMO, the crap was directed at me, for not knowing the proper name for the part in question....
Offline Porscheguy912
  • I'm a Big Shot Ninja.
  • It's MR. Moustache To you SIR!
« Reply #10 on: March 11, 2010, 11:01:43 PM »
Sorry Dwarf, But you have alot more foolishness to filter when working with us on here  ;)
Current: 1978 CB750F3
Past: 1974 CB550K
« Reply #11 on: March 11, 2010, 11:18:41 PM »
1st gear on any Honda is not a common problem you will just have to disassemble and inspect
Offline killerdwarf
« Reply #12 on: March 12, 2010, 05:36:01 AM »
I sent a mail off to the p/o. He responded back that he had no idea what was wrong. Ya right! F'n liar!! You could plainly see when compared to the bolts on the stator cover, that the shift cover was recently installed. Honda doesn't use clear silicone either. Liars piss me off.
« Reply #13 on: March 12, 2010, 09:46:35 AM »
If you read the "help needed with gearshift assembly" thread, you will learn, as I did, that the proper name for the "thingy" is "shift pawl".
Offline killerdwarf
« Reply #14 on: March 12, 2010, 04:51:54 PM »
I found the thread, and the pic. may help.
