Author Topic: Throttle Sleeve Opinion Please...  (Read 689 times)
Offline Johnie
« on: March 15, 2010, 05:03:25 PM »
When you guys put the grease under the new throttle sleeve is white lithium OK? Or should I use a heavier grease like wheel bearing grease to give the throttle a little slower reaction from that heavy carb spring?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Old Scrambler
Re: Throttle Sleeve Opinion Please...
« Reply #1 on: March 15, 2010, 05:12:46 PM »
I generally use the white lithium.......but not too much.  Regular grease tends to get soft and runs in the heat, and gets too stiff in the cold. I have also used graphite spray with good results.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Johnie
« Reply #2 on: March 15, 2010, 07:47:00 PM »
Thanks Dennis. I never thought about getting soft in the heat. Will do...
Oshkosh, WI  USA
« Reply #3 on: March 15, 2010, 08:44:23 PM »
I imagine silicon spray would work well too...
« Reply #4 on: March 15, 2010, 08:48:29 PM »
I don't see anything wrong with grease there, other than the goo, but I'll throw in the counterpoint.
I don't use anything and am happy with that.
