As part of an On-going CB750 cafe project I recently purchased several items from Carpy's parts page, Including a Fiberglass, "Dunstall" gas tank.
I'd like to share some of the things that I have noticed so far.
While the tank looks to be well made I have had several issues with fitting and one issue with the petcock mounting holes being pre-drilled.
In order for this tank to work with my project I have had to remove the triangular gusset under where the tank is mounted, though I notice that on his web site he has not removed these when using this tank on his bikes.
In order for this tank to work with my project I will have to add material to the front supports as the ears on your tank are much wider than the stock tank, though I notice that on his web site these do not appear to be built up on the frames for his bikes.
The rear of the tank does not sit properly on my on-going projects frame. I was encouraged to remove material until the tank fits properly, and weld new material on as reinforcement. However, once again, I notice that on his web site the frames do not seem to be ground down in this area.
To quote his site "... you can simply push the tank on just like a stock one, this took some research to get right, but now it is a treat and easy to fit to any 750 HONDA."
I understand that this is a custom tank and may take a bit of massaging to fit properly, but for $600.00 I expected less fitting troubles. have any of you experienced any of these issues while using this tank, would you mind sharing them with me?
I do not wish to remove any more metal from the frame and I think that cutting the tank would be foolish as well.
Do you think that this tank may have some defect?
I would really like to use this product, and continue to Document and Share my findings with it as it pertains to my on-going project, but this particular tank simply isn't going to work.
I sent Carpy an email but he has yet to reply, I'm sure he is a very busy man and I'm also sure he will be cool about it.
What do y'all think... am I wrong to think this should be less of a headache? I have posted this on another site too sorry if you have seen this already.
Thanks in advance
