Author Topic: IC's Interesting LED Gauge Lighting  (Read 60508 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: IC's Interesting LED Gauge Lighting
« Reply #25 on: March 18, 2010, 06:57:39 PM »
I wish I could have taken pics when it was all apart.
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #26 on: March 18, 2010, 06:59:36 PM »
i do remember the plastic having the tint, just don't remember it being mostly transparent!  thanks for the clear up, i think this is the direction i'm going to go.  the only problem with the CCRT, is that you need a small transformer, which is valuable real estate.  so starts the search for 80mm LED rings!  :D
Cormac
« Reply #27 on: March 18, 2010, 07:03:23 PM »
By file, you just mean the JPEG, right? Sorry, I'm a metal guy...software scares me :'(
Actually I still haven't figured out how to do the little blue box quotes... Oh well. Reason I'm asking is the speedo on the Bikes and Babes thread actually is pretty cool, I could do that. Anyone want to photo shop a red-head for the tach for me?
Oh yeah, slick as hell IC.
  • Like a well oiled
    • Undead Asphalt
« Reply #28 on: March 18, 2010, 07:20:43 PM »
thanks man, and ask the guy that posted the pinup speedometer if he could help you out.
where'd it go?
« Last Edit: March 26, 2010, 10:52:40 AM by Industrial Cafe »
Offline Zaipai
    • My Home page
« Reply #29 on: March 18, 2010, 07:28:58 PM »
Wonderful instructions.. Thanks man!
.: Scott :.
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #30 on: March 18, 2010, 07:59:53 PM »
when you search them buy 2-3 sets (4 halos) and search 'LED ring' in :eBay Motors>Parts and Accessories" and "electronics>Car Electronics"
I say buy a few sets cause they're like 5-10 bucks a pair with free shipping, and extras could help your friends.
http://cgi.ebay.com/ebaymotors/2x-80mm-Car-Angel-Eyes-light-24-SMD-1210-LED-Ring-White_W0QQitemZ250522539479QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3a544e95d7
Offline wannabridin
  • -Garrett
« Reply #31 on: March 19, 2010, 06:21:16 AM »
i bought a set of these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260570762624
but i didn't find the ones you had.  i searched halo instead of ring.  but for $10, that's not a bad deal at all!!  should of bought 2 sets of these for the price of 1 set of mine.  oh well, $21 still isn't a bad deal for this upgrade!  live and learn...
  • Like a well oiled
    • Undead Asphalt
« Reply #32 on: March 19, 2010, 09:32:13 AM »
that's the same part and the same company I got mine from. I just couldn't find it when I made the first post.
when you get them, check the solder joints and make sure they're not too thin.
you coulda just clicked the link I posted and bought those :P
EDIT: oh I see, you bought yours before I posted the link.
when I search I use ""80mm LED"" for my parameters
« Last Edit: March 19, 2010, 09:36:06 AM by Industrial Cafe »
Offline Jim F
  • go baby go
« Reply #33 on: March 19, 2010, 12:33:11 PM »
You have the front covered, but what about the brake lights
anything out there for the opposite end
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
  • Like a well oiled
    • Undead Asphalt
« Reply #34 on: March 19, 2010, 01:11:44 PM »
Jim
integrated LED tail/stop/turn signal with white LED tag light.
  • Like a well oiled
    • Undead Asphalt
« Reply #35 on: March 19, 2010, 01:48:24 PM »
OK!!
     so I delved inside my speedometer to see what was going on with the "burned out" LEDs.
see what color the plastic is? If it wasn't sanded off, you could see through it like glass
see how much space there is?
BRIGHT!! you can see the burned out ones at the bottom
    The ring is powered by 12v that goes into eight 129 ohm resistors (dropping 12v to 9v) each resistor powers three 3v LEDs.
     I removed and tested the resistor, (@129.5ohm) which was fine.
    testing the bad LEDs showed 16-24ohms of resistance meaning the diode fused together (I don't have a scope so I don't know exactly what happened in there)
I also tested the traces for resistance, opens, and shorts and they were fine.
I'm guessing it was a vendor issue with that particular reel of LEDs
___________________________________________________________________
next step is to disassemble these and use their LEDs to fix my gauges.
($5.34 a pair with free S/H -eBay)
the other one I want to use as a running light inside my headlight.
gratuitous pics of spare surface mount electronics-
piles of teeny parts!!
« Last Edit: March 19, 2010, 01:51:01 PM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #36 on: March 19, 2010, 01:54:47 PM »
I forgot, I stripped and soldered the LED wiring to the original lighting wires, then stuck them to the inside of the gauge with silicone to keep them separated and still.
also, here's a pic of the backside of the reflector
    I guess it's not white, it's sort of a green/white
Offline bistromath
« Reply #37 on: March 19, 2010, 01:57:15 PM »
Hey, you can order those LEDs from Digi-Key. They're PLCC-4 white LEDs. Osram TOPLEDs are probably the ones you want. And hey, you happen to know the values of those random SMT caps?  ::)
'75 CB550F
  • Like a well oiled
    • Undead Asphalt
« Reply #38 on: March 19, 2010, 02:16:20 PM »
I'm sure I could have, but then I wouldn't have that extra LED ring to put inside my headlight assembly as a running light.
no I do not. ;D
Offline Jim F
  • go baby go
« Reply #39 on: March 20, 2010, 10:34:40 AM »
Jim
Thats what I am looking for Brian
can you tell me where you got that from or did you make it from a kit
thank
Jim
  • Like a well oiled
    • Undead Asphalt
« Reply #40 on: March 20, 2010, 10:53:26 AM »
sure thing.
custom dynamics sells them for around 60 bucks.
http://cgi.ebay.com/ebaymotors/15-LED-Integrated-Light-Bar_W0QQcmdZViewItemQQhashZitem2558642042QQitemZ160396746818QQptZMotorcyclesQ5fPartsQ5fAccessories
 they're expensive but worth it, they have a good warranty and are they're in America.
to bend them you peel off all the 3M adhesive, sit em in hot water, bend them to the right shape, and let them cool that way.   I used "seal all" glue to mount em, it has methyl ethyl ketone in it, which melts plastic and bonds your tail light to whatever you stick it to.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #41 on: March 20, 2010, 11:20:00 AM »
Little bit of irony there, using an LED light strip to illuminate a license plate proclaiming your bike to be an ANTIQUE!!  :D
Your build continues to impress, IC!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
  • Like a well oiled
    • Undead Asphalt
« Reply #42 on: March 20, 2010, 11:32:03 AM »
you get the joke too huh?  HAHA :D
it's actually an LED tag light bolt on an aluminum bracket-
« Last Edit: March 20, 2010, 11:34:52 AM by Industrial Cafe »
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #43 on: March 22, 2010, 03:36:08 AM »
Wow I think I see my next mod coming....  Hey IC how big are the power inverters where did you end up hiding yours?
1975 CB750K
Project Back in Black
Offline ANVkevin
  • CB750K7
« Reply #44 on: March 22, 2010, 03:59:53 AM »
I can see a couple .0047uF in there.
Pretty cool you have a bowl full of surface mount caps.
Offline wannabridin
  • -Garrett
« Reply #45 on: March 22, 2010, 06:21:14 AM »
what would he need power inverters for on an LED application?
  • Like a well oiled
    • Undead Asphalt
« Reply #46 on: March 22, 2010, 06:22:01 AM »
no inverters, leds just use resistors soldered on the board.
Offline Laminar
  • Retsam
« Reply #47 on: March 22, 2010, 06:24:18 AM »
But what I want to know is how you got it to glow blue/green.  ???
I keeeeeed.
  • 1975 CB750K
« Reply #48 on: March 23, 2010, 03:02:56 AM »
Ahh I was wondering why led's would need those.  That one link posted took me to a site that had the cold cathod neon rings I think (which require the inverters).  I do have one more question how is the power consumption on those?  I know are bikes arn't the best on output and I am already running dyna ignition and the green coils..  I was considering the capsule halogen conversion to the headlight too and I am thinking I might be getting kinda close to max output....  Then again I guess if I just go really fast everywhere (is there another way?) and keep the RPMs up it won't matter right lol!
1975 CB750K
  • 1975 CB750K
« Reply #49 on: March 23, 2010, 03:08:15 AM »
I keeeeeed.
Read up in the post the gauge face is actually a semi see through green blue plastic, all you do is sand off the old numbers and use a new vinyl one and walla the light will come through the plastic as that kinda blue green light...  Man those look bad ass I am gonna have to do this now.  Damn you industrial as if I didn't have enough side projects with this bike lol!
1975 CB750K
