Author Topic: IC's Interesting LED Gauge Lighting  (Read 61070 times)
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
Re: IC's Interesting LED Gauge Lighting
« Reply #150 on: July 08, 2010, 04:50:21 PM »
So then I would be re wiring the whole gauge if I changed the brown/white wire then?
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #151 on: July 08, 2010, 05:32:03 PM »
changed?
Offline Laminar
  • Retsam
« Reply #152 on: July 08, 2010, 06:00:15 PM »
^ Good example of how not to insulate your wiring...
  • Like a well oiled
    • Undead Asphalt
« Reply #153 on: July 08, 2010, 06:10:14 PM »
yeah, completely coating the solder connections with silicone was a silly way of keeping them from touching.
Offline Laminar
  • Retsam
« Reply #154 on: July 08, 2010, 06:54:40 PM »
Good point. In my career dealing with thousands of electrical connections controlling multi-million dollar equipment, there's globs of silicon #$%* everywhere.
And heat shrink tubing and a lighter are so prohibitively expensive.
Offline CB750Ken8
  • I wanna ride...I wanna ride......Rawr MUST RIDE!
  • It's looking better everyday...jones'n to ride!!!
« Reply #155 on: July 08, 2010, 07:53:58 PM »
I used electrical tape on mine just because I didn't have any heat shrink (preferred method) and wasn't about to make an order specifically for heat shink tubing.
78' CB750 K8
Offline Laminar
  • Retsam
« Reply #156 on: July 09, 2010, 06:22:18 AM »
You can't go to Wal-Mart or an auto parts store and blow $5?
Offline CB750Ken8
« Reply #157 on: July 09, 2010, 08:22:00 AM »
I never thought about either of those places having any.
78' CB750 K8
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #158 on: July 09, 2010, 08:36:27 AM »
Or Harbor Freight.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline CB750Ken8
« Reply #159 on: July 09, 2010, 10:24:07 AM »
I was just too lazy since i had 3 rolls of electrical tape, and the fact that I still had to wrap the entire harness witch still looks like a rats nest up front, just with environmentally sealed connectors.
78' CB750 K8
  • Like a well oiled
    • Undead Asphalt
« Reply #160 on: July 09, 2010, 11:52:33 AM »
in my carreer of not having a job I figured silicone would do just fine.
dick.
Offline JAG
« Reply #161 on: July 15, 2010, 12:48:28 PM »
I got my led Angel Eyes in and started tearing down my gauges and I don't think there is any way that this thing will fit underneath the face plate.
I got the 80mm and everything. got any close up pics of this bad boy installed ?
[attachment deleted by admin]
Offline JAG
« Reply #162 on: July 15, 2010, 01:08:10 PM »
Pic didn't work I don't think. But not only is the depth seemingly not there but the diameter. It looks like it needs to be bigger round as well.
Is there something I'm missing here?
Thanks for the help.
Offline JAG
« Reply #163 on: July 15, 2010, 01:36:28 PM »
And this is on the tach side. Where the odometer switch us located it sits right in the way of where the led should be mounted.
Offline Laminar
  • Retsam
« Reply #164 on: July 15, 2010, 01:38:19 PM »
90mm rings on '76 550 gauges.
Offline The_Crippler
  • Work in progress.
« Reply #165 on: July 15, 2010, 01:45:57 PM »
Since it looks like my dreams of an all-in-one digital speedo/tach are dashed - I think I'm going to have to start thinking about doing this slick-ass mod.
  • Like a well oiled
    • Undead Asphalt
« Reply #166 on: July 15, 2010, 01:48:10 PM »
I didn't know the 550 gauges were that much larger.
 that's a nice looking face.
Offline JAG
« Reply #167 on: July 15, 2010, 02:20:41 PM »
Dang....  anyway to make it work with 80mm on the speedometer? This odometer is really in the way.
  • Like a well oiled
    • Undead Asphalt
« Reply #168 on: July 15, 2010, 02:41:31 PM »
maybe try stacking it up on double sided tape until it clears?
Offline JAG
« Reply #169 on: July 15, 2010, 04:08:44 PM »
Did you not use the 80mm dia. IC?
Offline bradweingartner
  • 74 CB 550 x2
« Reply #170 on: July 15, 2010, 04:13:17 PM »
Not all SOHC CB gauges are the same diameter. As an example, the 72 CB500 and 74CB550, both of which I've owned, have drastically different diameter housings.
Offline JAG
« Reply #171 on: July 15, 2010, 04:22:20 PM »
Wow that's crazy. I got a 750K, however I didn't think it would make a difference of what cc's it was.
Damnit. I really wanted to get this on today....
  • Like a well oiled
    • Undead Asphalt
« Reply #172 on: July 15, 2010, 04:47:39 PM »
yes
Offline JAG
« Reply #173 on: July 15, 2010, 04:51:13 PM »
If you did use the 80 mm .. how did you mount them then?
  • Like a well oiled
    • Undead Asphalt
« Reply #174 on: July 15, 2010, 06:09:15 PM »
with silicone.
my gauges are off a 77k
