Author Topic: 750 crankshaft - timing chain teeth - wear.  (Read 615 times)
Offline Franken750
  • Adventia b4 Dementia
« on: March 19, 2010, 09:37:10 AM »
Hi Guys.
About to begin an engine rebuild.
What level of wear is usually experienced on these teeth?
And what's the fix if the need replacing.
Thanks.
Franken
1982 Bol D'or CB750
1973 CB750 K3 in bitz in the Franken Lab.
1989 Porsche 928 S4
Re: 750 crankshaft - timing chain teeth - wear.
« Reply #1 on: March 19, 2010, 11:35:23 AM »
none and different crank
Offline kghost
« Reply #2 on: March 19, 2010, 11:49:47 AM »
Hi Guys.
Thanks.
Franken
Depends if your talking about the cam sprocket or the Crank.
On the cam... adjustable cam sprockets are available and pretty much required to set up an aftermarket cam.
Replacement of the cam chain is recommended during a rebuild. Chains are relatively inexpensive and of better quality then they used to be.
Stranger in a strange land
