Author Topic: Fuel tank latch hardware idea  (Read 4530 times)
Offline Fabricator
    • crmfabrication.com
« on: March 21, 2010, 05:22:39 PM »
On my '73 750K I took the fuel tank cap/latch assembly off for a proper paint job on the tank.  The original latch hardware would not drive out, and had to be drilled; rendering them garbage.  I measured for roll-pins, but realized that they would be a hassle to install around the latch spring.  I found that 4-40 machine screws are an excellent fit in place of the original pins.  I used one #4-40 x 1 1/4" long 18-8 stainless steel pan head philllips and another 1 3/8" long.  I secured them with nylon locknuts.  The total cost was under $2 at my local industrial fastener house.  These could also be ordered from MC Master Carr if you do not have a good vendor nearby.
See link: http://www.mcmaster.com/#machine-screws/=6bj9w8
Hope this helps someone!
Fabricator
"When in doubt, gas it. This; to be honest, doesn't always solve the problem, but at least it ends the suspense." (Mark Gardiner from "Riding Man.")
Life is too short to dance with ugly girls.....
Offline greasy j
  • lanesplitting
  • non serviam
Re: Fuel tank latch hardware idea
« Reply #1 on: March 21, 2010, 11:20:52 PM »
I am painting a tank right now and I might use your idea when it's time to put the cap back on.
I always try to save the pins, I know thats crazy, but sometimes I can reuse them, reflatten the end. but that's a pita compared to buying $2 worth of hardware. does it look odd?
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
« Reply #2 on: March 22, 2010, 04:21:07 PM »
I just wish i could find an oem latch spring :( :'( :'(
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline Fabricator
« Reply #3 on: March 22, 2010, 04:57:02 PM »
Greasy,
  I will modify this reply with a picture as soon as I get home with my good digital camera, as my attempts are not working in the dark garage with the camera in my phone.  I am picky about appearance, and think it looks good.  The head of a #4-40 screw is only 1/4" in diameter, so they really aren't noticed.  If you measure carefully, and only have one or two threads protruding through the nut, you can keep it quite neat.
Cheers
Fabricator
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #4 on: March 22, 2010, 11:08:29 PM »
cool, thanks. I'm gonna try it.
Offline Vampire
« Reply #5 on: June 28, 2010, 10:13:11 PM »
I want to use new pins on the fuel cap for my CB400F, but can't figure out a safe way to fold over the open end once inserted.
Thought of using a tapered tool and bashing it with a hammer, but knowing my lack of skill, would likely damage the tank in the attempt.
Any clever ideas on how to flare or fold the ends?
PS: I refuse to grow old until I grow up.
PPS: Growing up is for people with nothing better to do with their lives.
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #6 on: June 29, 2010, 11:23:55 AM »
This is what I use. A machined piece of brass with 2-56 cap screws tapped in both ends. Cap screws come in any color anodized aluminum as well. That way I can remove them any time necessary.
