Author Topic: Frame stiffening/reinforcement  (Read 11191 times)
Re: Frame stiffening/reinforcement
« Reply #25 on: March 28, 2010, 10:05:41 AM »
Thanks guys.
 I will probably change it a bit, and it probably wont  fit on stock applications, but would look nice with an alloy oil tank.
 I made an alloy front a few years back, as well.
 I was looking at 2 frames when I built that mount, and noticed a few things I was not happy with. Namely a 78F and a 76 Auto. The F  & K, has a pronounced seam that sticks out a long way from the boss, the auto is  flat and closer to the mount hole. The mount holes seem to be 2 diameters, so that leaves 2 choices of mounting bolts, maybe.
 I am thinking, I may be able to get a good fitting by installing an internally threaded sleeve in the frame hole, then clamping each side with a button head and washer. The big hole to motor, I was thinking of leaving undersize, then matching it to the actual motormount hole location.
754
