Author Topic: 1978 cb550k transmission clutch question???  (Read 960 times)
Offline jason teamshralp
« on: January 26, 2010, 06:15:36 PM »
I'm putting the clutch back on my 550 and don't know how tight to make the four bolts that my fingers are pointing to...
can someone please help me out...
Offline NickC
Re: 1978 cb550k transmission clutch question???
« Reply #1 on: January 26, 2010, 06:27:49 PM »
5.5 to 8.5 ft lbs
« Reply #2 on: January 26, 2010, 06:30:26 PM »
should they be bottoming out? or should they be loose? When they are tight there is no movement in the clutch arm on the outside of the case. You know the part that the clutch cable connects to the arm.
Offline NickC
« Reply #3 on: January 26, 2010, 06:31:42 PM »
They should be tight, sounds like you need to adjust the screw on the outside, along with the cable
« Reply #4 on: January 26, 2010, 06:50:13 PM »
okay that was it. I had the outside adjustment screw maxed out in the wrong direction.
Thanks!
Offline chadbenson
« Reply #5 on: March 23, 2010, 07:29:24 PM »
I'm wondering the same question myself. I have no clutch pressure or return at the lever. so i took off the clutch cover and decided to take out the clutch springs. But before I did I noticed that the springs were pretty compressed because the bolts were tight. When I go to put them back in i have no clue how tight to make them!! just tightin them until there isn't any more thread left? I'm clueless here......clymer manual is no help.
Offline NickC
« Reply #6 on: March 23, 2010, 09:26:47 PM »
Tighten them all the way down in a criss cross pattern.
Offline chadbenson
« Reply #7 on: March 24, 2010, 05:53:05 AM »
awesome thanks! i'll try that tonight when i get off work
