Author Topic: Will a dremel be able to cut through a 550 rear fender?  (Read 2794 times)
Offline elquenada
« on: March 25, 2010, 06:51:13 PM »
i dont have any heavy duty tools and I i'd like to shorten my rear fender.  will a dremel metal cutting disk do the job or will i just make a mess of it?
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Offline moham
  • .fnord.
Re: Will a dremel be able to cut through a 550 rear fender?
« Reply #1 on: March 25, 2010, 06:55:17 PM »
It would probably work but you might go through a few wheels doing it (would be a nice detailed cut, though!). An angle grinder with a thin cut-off wheel will have it off in a jiffy.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline Loki
  • my bike...so far
« Reply #2 on: March 25, 2010, 06:56:16 PM »
i just cut a portion of a exhaust with a dremel, because i couldnt use my grinder in the space, so you should be able to do it, just you'll go through alot of disks.
I don't have pet peeves, i have major psychotic f@cking hatred. - George Carlin
1977 Kawasaki kz 400
1999 Suzuki gsxr 600
1975 Honda cb 750f
1977 Honda cb 550k
Offline elquenada
« Reply #3 on: March 25, 2010, 07:02:37 PM »
thats what i was thinking.  I'll give it a try this weekend.
1975 CB 550
Lope de Vega
Offline Alan F.
« Reply #4 on: March 25, 2010, 07:32:53 PM »
The last time I needed my dremel I realized I was out of cutting discs, then I remembered how lame they were to work with.  A quick trip to sears found me some replacement discs from a craftsman rotary tool that are quite a bit stouter than the dremel discs.  Picture a smaller version of the big die-grinder cut-off wheels with the reinforced weave instead of the flimsy dremel discs.
I was able to mount these wheels in the dremel wheel's arbor too, I just had to nip the tip off a ball point pen to act as a centering spacer as the hole in these wheels is a tiny bit larger.  Found this pic on the web, it looks like what I'm talking about.
The discs I got are about 1-1/4 to 1-1/2" wide give or take and were actually cheaper since you can buy them as singles instead of by the tube of dremel discs, I think they were like $1.50 each
I highly recommend them.
Offline moham
  • .fnord.
« Reply #5 on: March 25, 2010, 07:35:19 PM »
Nice.
Good tip (pun intended)...
78 750K-The Ocho
Offline BlindJoe
« Reply #6 on: March 25, 2010, 07:38:35 PM »
You can probably buy an angle grinder  at Harbor Freight for less than you'd spend on bullsh#t Dremel discs
Offline Alan F.
« Reply #7 on: March 25, 2010, 07:57:06 PM »
Possibly, but it wouldn't produce the type of precision results you'd need when bobbing a fender.
Offline BlindJoe
« Reply #8 on: March 25, 2010, 08:00:38 PM »
use a thin disc, put tape where you want the cut to be, cut below the tape, flap disc the rest, then file
« Last Edit: March 25, 2010, 08:35:37 PM by BlindJoe »
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« Reply #9 on: March 25, 2010, 08:17:46 PM »
My bike came with a cutoff fender if your interested in swapping Ill send some pictures. Theres only so many of these left in the world it would be a shame to kill one!
Its hard to be wrong when you know nothing!
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: March 25, 2010, 09:37:58 PM »
I used a Dremmel to cut the dented front section off the front fender on my 550.  Went through it like a hot knife through butter, and only took one disc.
Offline McGriff
  • 76 550f
« Reply #11 on: March 25, 2010, 11:26:12 PM »
Yup, i got through the rear fender on my '74 750 in about 10 minutes and one disc with the dremel.  I used the angle grinder to smooth out the little variations and i think the edge came out alright.  i plan on covering the edge over with some car door trim.
1976 Honda CB550f
1974 k4 project
Offline camelman
  • Man... Myth... Legend
« Reply #12 on: March 26, 2010, 12:31:36 AM »
A dremmel tool can cut through a lot without destroying the disc.  Just make sure you keep the disc perpendicular to the cutting surface, and don't push hard.  It cuts very fast, and very accurately.  I see a lot of people destroy loads of dremmel discs in seconds because they are trying to force the cut, not keeping the disc perpendicular, or are leaning the disc through the cut.  Just let the disc do the work.
I use the thinner discs if I want to cut quickly.  The tool only has so much HP to offer.  If you use a thicker disc, then you will need to slow down your cut due to HP limitations.  If you have steady hands, and know how to use a dremmel, then you can accomplish what you want quickly and with minimal discs.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline elquenada
« Reply #13 on: March 26, 2010, 03:47:40 AM »
great tips and advice thank you.
my fender is in really nice shape so i am thinking I may buy a snottier one and cut that one instead.  I'd hate to ruin a good one.
1975 CB 550
Lope de Vega
