Author Topic: CB750 890cc Engine build [Codename: Rattlesnake]  (Read 66175 times)
Offline BLUE71TURBO
Re: CB750 890cc Engine build [Codename: Rattlesnake]
« Reply #25 on: March 28, 2010, 07:08:26 PM »
Where did you find the teflon buttons?????
  Looks like the one's that were on fleebay awhile back.   ;D
Online mick7504
« Reply #26 on: March 28, 2010, 07:24:57 PM »
MTC Engineering may be able to help Jerry.
http://www.mtceng.com/joomla_1_5/
If I was you
I'd be worried about me.
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« Reply #27 on: March 28, 2010, 09:34:31 PM »
I saw an old 900 piston kit on feebay and the guy had a pack of these that he was tossing in, unless they wanted regular clips and to let him know, yadda yadda. I sent him an 'Ask the seller a question' message using epay and asked if he had a set of buttons he would sell me. He asked for my paypal email, I sent it, he sent me a paypal invoice for 35.00 after shipping like an hour later. I had them in three days.
I feel like I scored.  :)
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
« Reply #28 on: March 28, 2010, 10:28:26 PM »
Big Jay has them guys, i got 2 sets with my nice 1000cc and 970cc forged pistons.  Look up APE engineering or CBR zone {same place}  or PM big Jay.... ;)
Offline BLUE71TURBO
« Reply #29 on: March 28, 2010, 11:00:48 PM »
 A.P.E.  Is the place.......Always Perfect Engineering !    ;D
  • Moderator
« Reply #30 on: March 29, 2010, 11:04:31 PM »
I'm sure there's a link to his site around here somwhere. ::) ::) ::)
Sam. ;)
« Reply #31 on: March 29, 2010, 11:16:23 PM »
And i though those were rolling eyes.... ;D they are looking at the link at the top of the page..... ;)
  • Moderator
« Reply #32 on: March 29, 2010, 11:49:28 PM »
Despite being a moderator, I was unable to get the eyes to roll to the top left side of the page. ;D ;D ;D
Sam. ;)
Offline MaaseyRacer
    • Fuelist
« Reply #33 on: March 30, 2010, 09:55:25 AM »
Impact wrench should take care of those stuck studs.  However, I would still use a full can of PB blaster on them over the course of a couple days.  The stuck one needs a little more help.
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
Offline michrobi
« Reply #34 on: March 30, 2010, 04:53:58 PM »
Installed a new 6008NR roller and two new HK2520 needle bearings in my primary chain sprocket shaft today. All the rest of the roller bearings are waiting for the undercut, then they'll go in. New bearings mmmmmmm so sweet.
-Mike
Offline michrobi
« Reply #35 on: April 05, 2010, 02:30:48 PM »
Here is my attempt to keep garnet out of my oil line. The three oil pump holes under the oil pan are plugged too. I'll let you know how that works out for me when I get the cases back from the media blasters.
What's that? Studs? Never heard of em.
-Mike
« Reply #36 on: April 05, 2010, 03:38:34 PM »
Put old 6mm screws/bolts in those exposed bolt holes Mike
Offline michrobi
« Reply #37 on: April 08, 2010, 10:52:56 AM »
The pin end of those RC buttons measure 10mm, but the ID of the pin from that 890 kit is 9.5mm.
Crap.   :-\
-Mike
Offline michrobi
« Reply #38 on: April 09, 2010, 10:37:55 AM »
Cylinders de-sleeved and ready for packing in the APE box.
30 minutes of the 'ol propane BBQ roast technique. Worked like a champ.
-Mike
Offline michrobi
« Reply #39 on: April 09, 2010, 11:02:24 AM »
The last of the 'parts' I needed for the short block assembly arrived today. Here is a quick inventory of everything that's in the build drawer.
890cc 67mm piston kit w/LA Sleeve Hi Nickel sleeves.
20-CFM head and .010" steel base gasket.
Cycle-X Super Rods.
DYNA 2000 ignition with wires and 3.0 OHM coils.
HD main and cylinder studs.
HD Cam chain.
Stainless brake lines and engine hex bolts.
New 8mm and 6mm flange nuts.
Honda NOS items...
Primary chains and tensioner.
Cam tensioner/slide/wheel.
Two transmission gears
All transmission ball and needle bearings. (Except the two not available from Honda, those are both aftermarket brands.)
All gaskets. (Except the head and base gaskets mentioned above.)
all O-Rings and Oil seals.
Fork boots.
Work to be done...
L/B crank. (I have the Cobra's lightened rotor.)
Trans undercut.
Cylinders bored, sleeves installed/bored.
I'm still working on new rockers and rocker shafts. And I'll get new main bearings when the crank gets back and I can measure it. I'll worry about that after Mike's done with the stage IV on the K6 head. I decided on the Megacycle 125-75 cam. This should be a fine build with the new Kerker megaphone pipes I got last summer, and the Mikuni 29mm smoothbores. I think it has a good chance of out snaking the Cobra.
-Mike
Offline tweakin
  • tear down
« Reply #40 on: April 11, 2010, 06:07:44 AM »
Looks great so far, that thing is going to be a beast!  What did you use to plug the oil holes?  I am taking my case to the blaster this week.  Did you end up using APE to get the broken studs out or did you take it to a local machine shop?  I live in Tacoma and can't find any good local machine shops to get my broken f2 studs out.
I will be watching this build for sure.  Thanks
Tige
Offline michrobi
« Reply #41 on: April 11, 2010, 09:31:05 AM »
I picked up a silicone plug assortment from Harbor Freight to plug the lines. It worked really well. I still have the case with the 4 stuck studs. I got another case that had the studs already removed so I wouldn't have to stress about it. It was cheap, but I'll have to start from scratch on the main bearings.
My micrometer is telling me the crank mains are 1.4175" or 36.0045mm. I was under the impression they were 36mm new, so how can they be larger than 36mm now ??? I guess maybe I have a pretty young crank and it just has .0045mm of oil on it. Does that sound reasonable? My calipers are only accurate to .00mm and according to the telescoping bore gauges the case journals are 38.95mm - 39mm avg. I have a good bore gauge on the way to re-take those case measurements before I order the bearings.
In other news... My toolbox sticker situation is improving.
-Mike
Offline tweakin
  • tear down
« Reply #42 on: April 11, 2010, 09:38:56 AM »
Thanks for the reply.  I also picked up new cases rather than deal with the broken studs.  I am using a K case with my F internals and cylinders and heads.
Offline michrobi
« Reply #43 on: May 12, 2010, 01:45:27 PM »
I picked up a Fowler electronic bore gauge at great cost, and after dicking with my Harbor Freight micrometer for a few days to identify where zero is I made my best main journal crank measurements. I was sure I would screw those measurements up, especially with as confusing as it is and with how it was my first time. Eventually I got to a point where it was obvious I was stressing too much and way over thinking it. After much internal debate, I went with the measurements I had and ordered a full set of Black bearings.
The new main bearings came in today. I plastigaged the top and bottom of the crank journals, then sequence torqued to 16.5 lbs. with stock main bolts. all five journals on both the top and bottom read exactly .0015" dry.
Every one, not even a slight variance. I guess the bore gauge was worth it.
That's good right? I wonder if those clearances will change once the HD main studs are torqued to 20 lbs.
« Last Edit: May 19, 2010, 11:26:56 PM by michrobi »
-Mike
Offline kos
    • m3racing.com
« Reply #44 on: May 12, 2010, 03:29:06 PM »
Why would you go up on the main stud torque?
KOS
220...221, whatever it takes.
Offline michrobi
« Reply #45 on: May 12, 2010, 03:50:37 PM »
Aren't those specced at 20 lbs.? I just assumed they were the same as the cylinder studs, I haven't actually opened them and read the instructions yet.
-Mike
Offline michrobi
« Reply #46 on: May 14, 2010, 08:45:59 AM »
Yeah, 20-22 lbs. it says for those studs. I'm not missing something am I?
-Mike
Offline michrobi
« Reply #47 on: May 19, 2010, 11:49:11 PM »
I finally tracked down the 30t gear I have been hunting for. I found it in the UK and had to have my brother go get it from a Honda shop there in the area. The transmission has two NOS gears because the bushing on the NOS gear to the left in this first shot had a couple nice gouges, and the mate on the countershaft had less than perfect dogs from wear. The rest of the gears are in good order. They all have visible ridges on the teeth that seem to indicate they're nice and young.
New bearings and circlips installed.
Everything moves real easy and rolls for a long time. Should perform well.
My crank, rods, top case and cylinders arrived at APE today, and the head and cam will be here before long. I could be ready for assembly in two or three weeks if everything goes my way.
8)
-Mike
Offline lordmoonpie
    • Moonpie
« Reply #48 on: May 20, 2010, 01:45:12 AM »
...and what's the advantage of them over normal clips?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline michrobi
« Reply #49 on: May 21, 2010, 09:49:35 PM »
They eliminate the chance that a clip is going to find its way into the cylinder wall.
-Mike
