Author Topic: 1976 CB750 K6 - CARBURETOR EXPLODED VIEW  (Read 3652 times)
saw750
« on: March 29, 2010, 10:15:29 AM »
Does anyone have a good exploded view of the keihin carburetor on the 1976 CB750 K6??
This is an update to my post regrading loosing a part on my carbs - inside the slides there is a retaining clip which attached thge the throttle rod to the slide AND A SPRING at the end of throttle rod.
i need that spring
there actually may not be spring..i havnt had the chance to pull intact slides apart to determine if one exists or not...
my bad...but according to to the available junk part/exploded views there is a spring washer...so therefore there must be a spring.
yes i know i should investigate the existing slides - but i am at the office and i thought i would as before i forget..
saw
Offline CycleRanger
  • No comment about being an
Re: 1976 CB750 K6 - CARBURETOR EXPLODED VIEW
« Reply #1 on: October 05, 2010, 06:26:53 PM »
Offline pidaster
« Reply #2 on: October 05, 2010, 07:22:35 PM »
Yep, there is a spring there. Unfortunately I don't have an extra. I would think you could pull another carb apart and find a similar spring that will work.
'76 CB750K
'82 CB450SC
'06 Vulcan 900
'98 Kawasaki Police 1000
'73 CB350 twin
« Reply #3 on: October 05, 2010, 09:21:58 PM »
I'll look: I may have one.
« Reply #4 on: October 07, 2010, 09:51:28 PM »
I have a whole carb (well, most of it) if you need one. PM me?
