Author Topic: Weber carb set-up  (Read 151779 times)
Offline BPellerine
Re: Weber carb set-up
« Reply #300 on: May 21, 2013, 08:25:02 PM »
thanks scottly am just taking my time so I don't mess up a 500 set of carbs!bill
1978 CB 750K ard and webers
another anfob
Offline Tintop
« Reply #301 on: May 22, 2013, 06:27:38 AM »
.....the po had too much non threaded stud sticking out of manifold and was compensating with cupped washers and thick rubber washers so not a lot of pressure was put on carbs.
There are two versions for mounting the carb to the manifold, and both are designed to eliminate vibration.  Webers are never mounted 'hard' to the manifold.  One uses a cup washer and rubber grommet (looks like two cones back to back, that's what I use); the other a spring and washer.  there are also two versions of the 'gasket' that goes between the carb and manifold.  One is a ring with o-rings on both sides; the other o-rings mounted in alloy (my choice).  The trick is to tighten everything down using a crisscross pattern, enough to seal, but still have some flexibility to kill vibration.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #302 on: May 22, 2013, 07:36:41 AM »
I have 3 sets on manifolds, pretty sure they are all hard mounted.. Bob pm if you need the  intake rubber connectors.. Only come in blue..
« Reply #303 on: May 22, 2013, 09:17:54 AM »
My carbs are hard mounted to the manifold. I figure the intake rubbers provide the vibration isolation. Also, my support at the rear of the carbs has rubber where it clamps to the frame.
Offline Tintop
« Reply #304 on: May 22, 2013, 11:27:31 AM »
Just saying....the way I described is the correct method, but then all my manifolds (including the XS) have been hard bolted to the engine.  I'll give you that the intake rubbers on a motorcycle will provide vibration isolation.  And yes, with intake rubbers you will need to support them.  Otherwise they will droop from the weight, and screw up the float level.  I would still use the soft mount (P/N 99005.146 / http://www.piercemanifolds.com/category_s/306.htm) to get a positive air seal.
77 CB550 Cafe build
Offline BPellerine
« Reply #305 on: May 22, 2013, 05:35:26 PM »
Yes I know that the mounting rubbers and washers I have taken off are proper mounting but I would have to modify studs to stop them from running out of thread when tightened so I saw a side view of scottlys carbs on this thread using bolts and it looked more compact and it must serve him well with the miles he does.I agree that they should be tightened evenly and with only enough force to seal them the mounting gaskets that came with them look are metal core with a soft rubber like coating to seal.it is all about learning for me bill
another anfob
Offline Tintop
« Reply #306 on: May 22, 2013, 06:15:10 PM »
Why not just buy shorter studs, or (easy fix) just add some threads to the existing ones with a die??  You mentioned they are a bit long, so add the thread to the manifold side of the stud.
I use a bolt & nyloc along with the cup/rubber washer setup, & soft mount gasket on the XS.
77 CB550 Cafe build
Offline BPellerine
« Reply #307 on: May 23, 2013, 05:36:54 PM »
I did not discard the studs and may go to them again but I like the bolts. much neater.bill
another anfob
Offline valt
« Reply #308 on: May 28, 2013, 04:05:46 PM »
So I just purchased a copy of the R.C. manifold from a member here. Since it doesn't use the stock honda rubbers to mount to the intake, I was wondering what you guys were using to mount them. I have heard of people either using radiator hose or silicon hose of some sort. Just wondering if you guys had a specific type that you used.
Offline BPellerine
« Reply #309 on: May 28, 2013, 05:58:18 PM »
hey another weber person to keep this thread alive!754 is the guy you should talk to about the different mounting methods he has a couple of versions.you should post a pic.I am new to webers but they ided mine from pic bill
another anfob
« Reply #310 on: May 28, 2013, 07:29:03 PM »
Look back towards the bottom of page 11. ;)
ccmclane
« Reply #311 on: May 28, 2013, 08:09:08 PM »
Reply # 271 - 275 if you are like me and have configured a different number of posts per page than the default.
« Reply #312 on: May 28, 2013, 09:02:31 PM »
RC manifols are the only one I know off that takes stock rubbers.. Do you have a pic of it?
Offline valt
« Reply #313 on: May 28, 2013, 09:16:41 PM »
Here are a couple of pics of a original RC manifold and the copy that I got. I measured a stock set of honda carbs with the manifold on and it seems the distances are much different from my RC manifold. I guess I can see if someone I know has a spare set of rubbers I can mock it up with.
« Reply #314 on: May 28, 2013, 09:57:07 PM »
It looks like your manifold may be an RC that was cut in half, then welded back together to move the carbs closer together?
Offline valt
« Reply #315 on: May 28, 2013, 10:03:00 PM »
I think its more it was cast as two different pieces then welded together. I think the welded spot is making it look closer together than the original one. Though they are probably very close if not exactly the same.
« Reply #316 on: May 28, 2013, 10:17:13 PM »
It still looks to me to be an RC manifold with 3/8-1/2" sectioned out of the middle, then welded back together. ( I hope Jim F doesn't see the weld job... :o  ;))
Offline valt
« Reply #317 on: May 28, 2013, 10:35:50 PM »
Honestly I don't have an original one, so I can measure the manifold I have but unless someone has measurements from an actual one its hard to tell.
« Reply #318 on: May 28, 2013, 10:38:32 PM »
Correct, mine took stock rubbers  ;)
Offline bear
  • Leeton in Australia
« Reply #319 on: May 28, 2013, 10:55:09 PM »
Ours. ;D ;D ;D
Brian
Offline johno
« Reply #320 on: May 29, 2013, 03:56:14 AM »
hi guys,
   yes it is an RC manifold.........    RC manifolds use stock rubbers...........the combo of stock rubbers required  are four of 2&3 rubbers............NO 1 & 4
That get things lined up nicely,    interesting photo looks like welded one side not the other ????? ::)
Scottly Im not sure about the narrowing of the manifold as the carbs are so close allready the throttle shafts have to be cut to get the carbs mounted ...almost touching
Its very easy to break the manifold  in half  or the cable mount wings while putting them into the head  mounting rubbers...........ask me ::)
ciao boys.
Offline valt
« Reply #321 on: May 29, 2013, 06:03:16 AM »
hi guys,
ciao boys.
Yah I guess I wasn't super clear there, those are two different manifolds. One is a actual RC manifold and the other is the copy that was cast in two pieces and welded together.
« Reply #322 on: May 29, 2013, 02:27:03 PM »
Ours. ;D ;D ;D
Brian
Yours.... ;)   evolution 101.... ;D ;)
Offline Tintop
« Reply #323 on: June 02, 2013, 05:39:02 PM »
Quick update on the jetting in the 40DCOE on the sidecar.
Mains - 135 / Airs 175 / Emulsions F11.  Nice tan centre.  Now idles (50F9's) @ 1500 without loading up.  No flat spots, and pulls red line+.
77 CB550 Cafe build
Offline bear
« Reply #324 on: June 02, 2013, 06:00:43 PM »
Sounds like your geared to go Brian.
When is your first meeting?
Brian
