Author Topic: Weber carb set-up  (Read 151854 times)
0 Members and 10 Guests are viewing this topic.
Offline BPellerine
Re: Weber carb set-up
« Reply #550 on: June 23, 2015, 06:48:43 PM »
way to go jonny!
1978 CB 750K ard and webers
another anfob
« Reply #551 on: June 23, 2015, 08:33:16 PM »
You'll have this down pat by the time I get my 1000 up and running then we can start on my Weber setup.  ;D
I have NO clue whatsoever about them except that they are in a box awaiting use.
Offline jonnycakes
« Reply #552 on: June 23, 2015, 10:25:11 PM »
BTW, the cover for the cold start can be removed; the springs keep the valves seated.
I got little aluminum covers to replace the cold start assembly
'Matic-Fanatic
« Reply #553 on: June 23, 2015, 10:30:07 PM »
That 150 air jet still bugs me, but hey, if it works, it works! 8) 8)
Offline jonnycakes
« Reply #554 on: June 23, 2015, 10:47:15 PM »
The Automatic seems to want leaner main jet, but richer when it finally hits the upper RPM.
'Matic-Fanatic
Offline Bill/BentON Racing
    • BentON Racing
« Reply #555 on: June 24, 2015, 04:58:46 PM »
K, keep us posted, thanks,  Bill
BentON Racing Website
BentON Racing Facebook
Offline BPellerine
« Reply #556 on: June 24, 2015, 05:24:46 PM »
what change did you notice when you changed emulsions,there does not seem to be a standard setting that works with similar engines with these carbs.billp
another anfob
« Reply #557 on: June 24, 2015, 06:13:36 PM »
Something wrong there should be able to work it out with jets.
 I don't have the manuals, but they point you toward which jet. You should work with sometimes.
When you say seems to want a leaner main, it sounds like you are not on the main yet..
« Reply #558 on: June 24, 2015, 09:21:42 PM »
You may be on to something, Jonny; with 125 mains, 185 air corrections, and foam air filters my bike is rich at WFO from 4500 RPM up, measured with a sniffer on the dyno. Are you running open stacks?
Offline jonnycakes
« Reply #559 on: June 25, 2015, 06:19:45 AM »
3" open stacks......I went from 115 to 120 main jet last night and the burble came on the highway. No noticeable change at the top end.
When I used the 125s, the carbs were soaking wet with gas when I pulled the apart and my milage was 20mpg which is really bad even for a hondamatic
I also tried 35f9 idles...way too lean, 40f9 were much better, I couldn't feel any difference when I went to my 45F8
With the matic, there's no slipping the clutch to get past any flat spot
« Last Edit: June 25, 2015, 08:44:28 AM by Jonnycakes »
'Matic-Fanatic
Offline jonnycakes
« Reply #560 on: June 25, 2015, 08:59:42 AM »
If I was smarter Id have this by now
I'm using this:
http://www.lainefamily.com/images/WeberTuningManual.pdf
'Matic-Fanatic
Offline BPellerine
« Reply #561 on: June 25, 2015, 10:21:31 AM »
how about a pic of your bike with the webers,must look cool,when I firs got my webers I was told that the 115s may be too lean but they work okay,200 air,f11 tubes,bill
another anfob
« Reply #562 on: June 25, 2015, 10:21:42 PM »
3" open stacks.....
The carbs shouldn't be soaking wet with 125 mains??? Do you have the proper stacks? I noticed in the tuning guide you posted that there were two different style aux venturi; one for stacks and one without. Bill P's 38 carbs didn't need the stacks to lock the aux in place like my carbs. Do your stacks look like mine on the left side, or do they have a flat flange with two mounting holes like the ones I sent Bill?
« Last Edit: June 25, 2015, 10:27:31 PM by scottly »
Offline jonnycakes
« Reply #563 on: June 26, 2015, 05:13:36 PM »
3" open stacks.....
yup, only my stacks are longer..........
'Matic-Fanatic
Offline BPellerine
« Reply #564 on: June 26, 2015, 06:17:07 PM »
this is what I mean when two engines are far apart on jetting,yours 849,scottlys 836,both with cams,frank and scottly get good mileage I thought.but who knows for sure.do you have a good mid response compared to stock carbs?bill
another anfob
    • BentON Racing
« Reply #565 on: June 27, 2015, 09:13:17 PM »
32mm chokes installed. Hardware polishing almost finished,Thank you Bill Pellerine, they've turned out well, Bill  ;D
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #566 on: June 28, 2015, 03:49:17 AM »
you get those out my garage billy?
...Save a tree, eat a beaver...
    • BentON Racing
« Reply #567 on: June 28, 2015, 05:39:21 AM »
Nah, but the RC chrome ignitignition....well that's another story. ;D
  • Gusto mo titi ko?
    • project
« Reply #568 on: June 28, 2015, 07:54:09 AM »
that was actually polished
« Reply #569 on: June 28, 2015, 09:34:23 AM »
Big mean looking carbs.. I love em........go under the heading of exotic parts..
Offline BPellerine
« Reply #570 on: June 28, 2015, 09:35:22 AM »
now they look NEW! polished screws too,they must be as close to new as you can get,you have 170 air,f7 emuls,105 main in case you were wondering.could   not get the stain from boots off but there will be others on there,would have polished the stuff too but we know why not!haha .also new pump o rings on there billp
another anfob
Offline BPellerine
« Reply #571 on: June 28, 2015, 09:39:00 AM »
everything else looks ordinary after having webers!
another anfob
« Reply #572 on: June 28, 2015, 10:56:34 AM »
There you go again Billy Bling  ;D  yeah yeah I'm jealous but I need to finish the engine before I'm NOW forced to bling up mine too  ;)
    • BentON Racing
« Reply #573 on: June 28, 2015, 02:23:50 PM »
Nah, just send them this way!   ;D
« Reply #574 on: June 28, 2015, 02:35:08 PM »
Don't have time! Just torqued the head and gathering up the little odds and ends. Cam time  ;D
