Time is money for me
I've got the time, but not the money.
Send me some money and I'll not only save you some time, but also some money on parts that will never get used.
I went back to 30mm chokes, with the same 3.5 aux and 110 main as the last test, but with a 200 air, as I knew the smaller chokes would be richer. After a couple of warm-up runs to make sure the pistons weren't going to go China Syndrome at 7250 RPM, I let it rev a bit more than before.
I also figured out how to use the vertical cursor option to show the readings at a particular RPM. The A/F readings were still a bit wonky, but after cleaning the sensor again (by carefully heating it with a propane torch to drive off the fuel residue), it seemed to operate properly for the next test. As most folks seem to have 4.5 aux, I ran another test with them installed in place of the 3.5s.
The last graph compares the tuning I've run for 36 years, that my "butt dyno" thought was good, compared with the 110 mains and 200 airs.
