Author Topic: Weber carb set-up  (Read 151705 times)
Offline Tintop
Re: Weber carb set-up
« Reply #875 on: December 07, 2018, 11:26:09 AM »
https://photos.app.goo.gl/wPULKhbfcftwrKbH9
https://photos.app.goo.gl/kL1gedAvCLeCPCyQ6
 Does anyone have a favorite gasket/rebuild kit source?
https://www.piercemanifolds.com/  this has been my go to place for DCOE stuff for many years, haven't yet said they couldn't either supply or fix.  They have some videos you might want to consider adding to your Christmas list.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #876 on: December 07, 2018, 08:32:19 PM »
Don, I've never had to replace either of the two gaskets; one is where the top of the carb meets the main body, and the other is under a square plate on the bottom of the carb. Replacing the top gasket requires removing the float, which can lead to a broken post just like Honda carbs, so if it ain't broke, don't fix it. ;) If you do order parts, I would include a set of 50F9 or F8 idle jets.
« Reply #877 on: December 07, 2018, 09:28:35 PM »
 Thanks, I got my magnifying glass out and those are 45F9. Maybe that's why the idle screws are out 1 3/4 turns, should they be around 1 turn with 50F9?  The chrome on the top plates is gnarly, mostly gone except under the hanger brackets. I may sand or scrape on it a little and see what happens.  I ordered some cheap gaskets off ebay just to get the carb base and the top to air filter gaskets and a sheet of fine uni filter media.
The parts that remove easy will get a bath in the ultrasonic. Then I'll spray and blow them clean, there's no gunk at all but they have a little gritty feel, like they were nearby when the manifold was blasted. I'm not sure I'm ready to go whole hog cleaning them.
« Reply #878 on: December 10, 2018, 11:42:35 AM »
 Hurry up Christmas bonus, Papa wants some weber stuff!
 I have a sweet running K2 that belonged to an old friend, it mysteriously has a replacement frame with no numbers or tag and I've never titled it although I do have the paperwork to do so. The guy that built the engine (also built, owned and raced my drag bike)  couldn't remember if it had an 836 or a less common bigger bore kit that he used when the 836's were sold out.  I wish they both were still around, I would ask so many questions.
I got filter media today and sliced and diced the filters back together. The media is a bit too thick and the filters are a little worn but they should look good when all assembled.
« Last Edit: December 15, 2018, 03:47:13 PM by Don R »
« Reply #879 on: December 15, 2018, 03:49:43 PM »
 Did anyone post a tune-up for a big cc engine? I wonder what came in the RC Cobra Webers?
« Reply #880 on: December 15, 2018, 05:42:27 PM »
IIRC, we set up Jerry's bike up with 32 mm chokes and 115 mains. He has yet to drag it down here for a dyno test. ::) ::)
« Reply #881 on: December 15, 2018, 05:58:38 PM »
The main reason I recommend 50 idle jets has more to do with cruising speeds than idle screw setting; yes they are related, but I've found that the idle jet is still well into play when cruising at a steady 70 mph or so. With smaller jets, I've experienced a bit of a lean miss under those same conditions.
« Reply #882 on: December 16, 2018, 10:37:59 AM »
Sounds like an invite to me  ;) ;D
Well the retirement is set. 6 days next week and I'm done. Heading to St Thomas 1/1/ through 4/3. The plan is to work on bikes when I return. May as well do it in AZ before it gets too hot. Target is July 4 week for the 50th in Ohio. I will have to decide which bikes to haul.  ;D Both 750's, one 750 and CB1100F, one 750 and the CBX???
« Reply #883 on: December 16, 2018, 07:06:23 PM »
Late April/early May is usually decent weather, if not a bit windy. ;D
« Reply #884 on: December 18, 2018, 05:01:38 PM »
  I ordered 4 jets, silicone hose and 8 wrap around clamps from Pegasus racing supplies. They are relatively close and had all three items.  I'm swapping the gas tank on my gl1000 so I'll be ready to play when the gl goes back together.
  Edit, this just in- 50 F 9 jets, hose and clamps arrived. Now to get a proper length measurement and determine a good way to make some beautiful cuts on the black hose.
 When grandkids watching time is up I need to get to the shop for more than a half hour at a time. I hope to still be at it when my grandsons are big enough to participate. Their Moms are/were pretty good racers.
« Last Edit: December 20, 2018, 01:09:26 PM by Don R »
« Reply #885 on: December 25, 2018, 04:07:31 PM »
 Santa brought the Haynes, Pat Braden and Brooklands Weber books. I already read up on aux venturis and emulsion tubes in the Brooklands. Interesting stuff and agrees with what I found here.
Offline Tintop
« Reply #886 on: December 25, 2018, 04:42:49 PM »
Lots of good reading for the holidays.  Merry Christmas
77 CB550 Cafe build
« Reply #887 on: December 26, 2018, 03:22:34 PM »
 If I read and comprehended everything in these three books, I'd be a real expert. I worked on hose cutting today, a miter box and a razor sharp antique bread knife seem to be my favorite choice of weapons.  As soon as the 78 Goldwing is back to being one big piece I'll clean up and begin weber fun.
Offline valt
« Reply #888 on: January 09, 2019, 01:56:22 PM »
I have a question for everyone, apologies if it has been mentioned before. But I have a R.C. manifold with a pair of DCOE 40s on it. What I want to know is what throttle lever to use, all of the weber ones I can find are for cars and don't allow you pull direction up on them. I have circled the part I am talking about in red in the picture below.
« Reply #889 on: January 09, 2019, 03:37:44 PM »
 I ordered Weber gaskets from Europe, not the best idea. A slow boat from China is quicker. 32 days so far but they should arrive this week. L0L!
Offline Tintop
« Reply #890 on: January 09, 2019, 03:53:45 PM »
Lots of different lever solutions here > https://www.piercemanifolds.com/category_s/181.htm
77 CB550 Cafe build
Offline valt
« Reply #891 on: January 09, 2019, 04:08:59 PM »
Unfortunately none of those will work with the R.C. manifold. As I need a lever that I can pull straight up on. The one in the picture I posted is actually what I am after, almost all of the R.C. setups I have seen use a similar lever. I'm not even 100% positive that it is a lever made for a DCOE . But I have been unable to find a lever that looks like that.
« Reply #892 on: January 09, 2019, 07:06:30 PM »
They are easy to make, drill 2 holes  file the rest out..
Offline valt
« Reply #893 on: January 09, 2019, 07:08:41 PM »
Yah that is certainly something that I will probably end up doing. I just assumed that there was some lever that people were using back in the day. Since the R.C. setup was sold in magazines and I assumed people weren't just making their own levers.
Offline RAZZ
« Reply #894 on: January 09, 2019, 11:28:45 PM »
Hi mine are made like This ( i have a MPD manifold now it works perfect)
« Reply #895 on: January 10, 2019, 07:29:58 PM »
That looks like it may be two levers, fit onto the same shaft?
RAZZ, I like those spools! I don't think I've seen anything like that before on Webers?? Now you have me thinking. ;D
« Reply #896 on: January 10, 2019, 08:04:48 PM »
 If i find my box of Weber linkage, i will see what is there.. came from a sportscar shop, but might be something in there.
 Scott I think the wheels may have been used on Sudco Harley kits, but easy to make from AL. .
 HD Keihins used a steel one, they might be reasonable..
Hmmm, look what I found..!
« Last Edit: January 10, 2019, 08:14:40 PM by 754 »
Offline valt
« Reply #897 on: January 11, 2019, 05:32:48 AM »
Hah yah my friend sent me that exact linkage. I think the S&S wheel is pretty close to working. But I will just make a cardboard template and make my own, instead of trying to co-opt a S&S setup. I really need to get the linkages on there, I was able to get the whole thing running but it has a long way to go. It was able to idle seemingly on two cylinders though.
« Reply #898 on: January 11, 2019, 07:43:20 AM »
Frank, you're on to something. Keep digging.
Offline Tintop
« Reply #899 on: January 11, 2019, 07:52:33 AM »
This is another linkage version.  I used this on the sidecar, worked very well with a nice smooth pull.  Does require a return spring, but all Weber set-ups hould have one.
https://www.piercemanifolds.com/product_p/pm40930.htm
77 CB550 Cafe build
