Author Topic: NOBORU Gaskets  (Read 4047 times)
Offline Clutch Cargo
NOBORU Gaskets
« on: January 21, 2006, 06:09:34 AM »
Does anyone have any experience with NOBORU gaskets for the CB750 motor?   I got burnt last year with Athena gaskets - all of the side covers leaked - and I'd like to avoid that experience again.  I'll make my own if I can't find a good set.
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
Re: NOBORU Gaskets
« Reply #1 on: January 21, 2006, 07:29:23 AM »
The time you'll burn making your own would make paying Honda for an original more attractive.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: NOBORU Gaskets
« Reply #2 on: January 21, 2006, 07:45:21 AM »
         I've made my own in the past but, there's a shop in town that advertises that they have a
    equipment to offer a gasket making service. I haven't checked it out yet. Has anyone ever heard
    of this before and had any experience with it? I don't know if they just make cover gaskets only,
    or if they can make head gaskets too. I do intend to check this out, could be the way to go.
    We'll see you later,  Bill
Member # 1969
jsaab2748
Re: NOBORU Gaskets
« Reply #3 on: January 21, 2006, 09:53:33 AM »
Something I'll offer as advice: Think of it like this. You'll never go wrong with genuine Honda parrts. (seals or gaskets) They were designed for your bike. Use them, and forget it. Your oil leak issues will be eliminated once they are properly installed, and you'll be glad you chose them. They cost a little more, but it's worth it. Speaking from experience. Good luck..jim
Re: NOBORU Gaskets
« Reply #4 on: January 21, 2006, 11:53:53 AM »
Used Noboru for years with never a problem Just remember that all gasket surfaces need to be "mirror finish" clean  with only grease (clean) on paper gaskets with nothing on the head and NEW rubber pucks under the cam towers and a NEW tacho drive seal whilst the cover is off
Offline 78 k550
Re: NOBORU Gaskets
« Reply #5 on: January 21, 2006, 04:03:26 PM »
There is a repair shop here in town that has a gasket machine. I have had a couple made for my Bultaco's. No problem with them. I thought it was a bit pricey. Found I could get some nos for just about the same price.
Paul
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline bill440cars
Re: NOBORU Gaskets
« Reply #6 on: January 21, 2006, 06:21:55 PM »
 Thanks Paul, I'll probably do the same. :)      Bill
Member # 1969
