Author Topic: Diesel 750  (Read 8480 times)
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Diesel 750
« Reply #25 on: April 01, 2010, 11:28:14 AM »
Just to clarify....
your motor is 750 cubic INCHES per cylinder.
so... yea. 8)
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline SohRon
Re: Diesel 750
« Reply #26 on: April 01, 2010, 11:31:42 AM »
Right you are! but, inches, centimeters... what's the diff? If it doesn't matter to NASA, why should I be concerned?  :o ;)
« Last Edit: April 01, 2010, 11:33:58 AM by SohRon »
Offline HavocTurbo
  • Can you tell?
Re: Diesel 750
« Reply #27 on: April 01, 2010, 11:47:57 AM »
lol huge air difference there man.
I'd siggest looking at the holley or edelbrock carbs. Maybe a demon carb as well.
Stick one of those on each cylinder and now we got something.  ;)
I bet oil injection would be an easy mod on those carbs.
09 XL883L - No Name
Offline moham
  • .fnord.
Re: Diesel 750
« Reply #28 on: April 01, 2010, 12:18:11 PM »
Whitewalls would just look gaudy, IMO. Jeeze, man... show some class!  :D ;D
dude, whitewalls give you more traction. and clubmans will give you at least 3, maybe 3-1/2 more hp which you're gonna need with that set-up.
also, how big's your nitrous bottle?
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline SohRon
Re: Diesel 750
« Reply #29 on: April 01, 2010, 12:46:32 PM »
Saaweeet! Would work well with a 12x12 exhaust, too!
Well, since we're putting carburetors on this diesel engine  ::) we might as well go for that, too! But I wouldn't want to add too many more systems as it might become ungainly and difficult to ride...
Well, there is that to consider. Hmmmm.
« Last Edit: April 01, 2010, 12:50:20 PM by SohRon »
Offline eideteker
Re: Diesel 750
« Reply #30 on: April 01, 2010, 01:01:44 PM »
It won't become ungainly until you add the propane, trust me.
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline HavocTurbo
  • Can you tell?
Re: Diesel 750
« Reply #31 on: April 01, 2010, 01:03:11 PM »
x2!! screw NOS.... propane is where its at for the smokers.  ;D
09 XL883L - No Name
Offline The_Crippler
  • Work in progress.
Re: Diesel 750
« Reply #32 on: April 01, 2010, 01:06:06 PM »
Two other things to bear in mind:
1.) A popular mod is to paint the engine.  I would not do this, as it will mess with the air-cool properties of it.
2.) Going faster than 88mph while drafting a Delorean may cause one of you to travel forward in time.  Just sayin'.
Offline HavocTurbo
  • Can you tell?
Re: Diesel 750
« Reply #33 on: April 01, 2010, 01:14:58 PM »
I dunno... I think the smoke would mess with the space time continuum.
09 XL883L - No Name
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Diesel 750
« Reply #34 on: April 01, 2010, 01:17:23 PM »
Your MPG should be pretty good.  That is if you are pulling enough of a load.  You can get 465 TonMiles with anough cars in tow.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
  • Work in progress.
Re: Diesel 750
« Reply #35 on: April 01, 2010, 01:18:57 PM »
True....but then you gotta worry about hobos in the airbox.
Offline HavocTurbo
  • Can you tell?
Re: Diesel 750
« Reply #36 on: April 01, 2010, 01:20:44 PM »
Worse than mice those guys are.
09 XL883L - No Name
Offline moham
  • .fnord.
Re: Diesel 750
« Reply #37 on: April 01, 2010, 01:23:37 PM »
just throw a can of beans over the side...
78 750K-The Ocho
Offline SohRon
Re: Diesel 750
« Reply #38 on: April 01, 2010, 01:53:35 PM »
A good point, and timely as I was playing with painting the engine fire engine red, but was concerned it might attract attention... I'd like to keep the bike a "sleeper" if I can...
Isn't that more properly "GPM" with one of these engines?
  • Work in progress.
Re: Diesel 750
« Reply #39 on: April 01, 2010, 01:56:58 PM »
Which is unfortunate, really...despite attracting attention and overheating the engine, the color red adds a consistant 10mph.
Offline HavocTurbo
  • Can you tell?
Re: Diesel 750
« Reply #40 on: April 01, 2010, 01:59:18 PM »
Isn't that baby water cooled though?
You could powdercoat it then..... OOH OOH SEND IT TO ME!!!
I have THE coolest metallic red powdercoat.
09 XL883L - No Name
Offline kslrr
Re: Diesel 750
« Reply #41 on: April 01, 2010, 02:05:40 PM »
Yes, Diesel 2-strokes are water cooled.  And they have injectors (which can weigh as much as a 350 twin engine), 2 to 4 exhaust valves, large blowers and NO oil injection.
Oh, and the oil sump holds about 200 gallons.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline weekend_junkie
  • I bet you think I'm some
  • Member # 15859
Re: Diesel 750
« Reply #42 on: April 01, 2010, 02:06:41 PM »
what about an extra wide rear tire?
I thought about that, but I'm going to stick with the stock rear set-up here...
Stock as in spoke wheel, or stock as in caboose?  Please be specific so that newcomers like me can steal your build idea eventually.
Dan
Offline SohRon
Re: Diesel 750
« Reply #43 on: April 01, 2010, 02:08:28 PM »
That's true! That's true! (gets excited) WoW! Red metallic powdercoat!
Of course, while it would look great on a show bike, I probably wouldn't want it on a daily driver, where I'd rather it just blended in with the rest of the traffic...
But it would look great, otherwise!
We decided to go with larger wheels with an extended fork and shorty shocks. Should do the trick.
« Last Edit: April 01, 2010, 02:11:03 PM by SohRon »
Offline Frankencake
  • Yesssssss,
  • "I like the old junk"
Re: Diesel 750
« Reply #44 on: April 01, 2010, 02:46:46 PM »
I was given one of these engines back when I was building my race tractor.  I used a Cub Cadet 70 frame and put this baby in it.  I had to run a little higher air pressure in the front tires and a few cups of water in the back wheels to get the balance right, but boy do I get the looks from the chicks. That alone outweighs all of the extra work that I had to do.  As far as exhaust goes I did a 12 into 1 into 12 again just to kind of play around with my conduit bender.  And the carburetor is just a plain old 55 gallon drum with a garden hose as a jet.  I mounted the tank up high to get the right head pressure for my float, which is a basket ball, and for starting the beast, I have a black powder ram set-up (an idea that I got from my civil war re-enactment days).
333:  Think "Shakeweight".
Offline ieism
Re: Diesel 750
« Reply #45 on: April 01, 2010, 02:47:21 PM »
Upgraded clutch springs from M3 racing would probably be a good idea too.
---cb550---
Markcb750
Re: Diesel 750
« Reply #46 on: April 01, 2010, 04:17:56 PM »
No one takes true genius seriously.
Especially those in authority.
Offline SohRon
Re: Diesel 750
« Reply #47 on: April 02, 2010, 05:38:46 AM »
I decided to forgo the project when all of the frame modifications left no room for a cup holder. Too bad.
To all who participated in this little exercise, thank you for your wonderful senses of humor and your willingness to take a joke and run with it. Great bunch of guys.
And I hope you all had a wonderful 1st of April!
  • Work in progress.
Re: Diesel 750
« Reply #48 on: April 02, 2010, 07:08:37 AM »
Yeah, that was a surprising amount of fun.
Chuck M
Re: Diesel 750
« Reply #49 on: April 02, 2010, 09:01:14 PM »
I was researching this swap when I noticed that the fuel consumption rating is in gallons per minute!  Your gonna need a bigger tank!
