My engine is seeping oil out of the left side end cap of the valve cover. Its actuall leeking out of both sides but more prominently out of the left. When I pulled my engine apart this winter I didnt touch the rockers at all. In fact the only thing I did do is install new o-rings onto these rocker end caps.
I have the valve cover off now and Im looking around for leaks but I dont se anything obvious. I think it could be a loose tower puck but those dont really seem to be in such bad shape. Any other place I should look at while I have this think open?
![Huh ???](http://forums.sohc4.net/Smileys/default/huh.gif)
Edit: I just found these two old posts and Im off to reinspect for wear:
http://forums.sohc4.net/index.php?topic=20408.msg212239#msg212239http://forums.sohc4.net/index.php?topic=25094.msg264503#msg264503Edit#2 Upon further inspection I realized that one of the rocker shafts was installed backwards (the screw hole was facing inside). This was the one shaft that was leaking the most, although Im not positive this is the answer to my problem. Some of the pucks appear to be a bit loose so I will re-glue them with some high tack sealent and hope for the best. One positive thing is that the shafts appear to be centered with no gaps of obvious deformaty visible.
