Author Topic: 1978 CB750K — Post 836 OIL PRESSURE - Seems bad :(  (Read 254995 times)
Offline SKTP
Re: 1978 CB750K - drill baby drill
« Reply #425 on: March 27, 2013, 08:56:29 PM »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #426 on: March 27, 2013, 09:02:00 PM »
Yeeeeeh Hah.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #427 on: March 28, 2013, 06:14:30 AM »
Soooo.... what gives?  ??? Successful removal?  8) Helicoil?  :) Replacement head?  :( Photoshop?  :o Inquiring minds want to know!   :P
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline SKTP
« Reply #428 on: March 28, 2013, 09:51:40 AM »
Ok...so I drilled regular bits...then tapped it with that standard tap with the hope that it would pull out threads. It didn't so I basically had a slightly off center threaded on the outside and threaded on the inside drinking straw...I got some of those tiny dremel diamond cutting bits...worked them some...then I just went for it with the M8-1.25 tap...
It pulled out some old threads and tapped new ones nicely. It was not perfectly centered so after some tapping it became too difficult to turn and I did not want to force it. So I check the bolt with the spigot and it was the slightest bit off but nobody but me would ever know, and it was like a millimeter shy of being flush...so (and this is the part you won't like) I cut off 2 threads on the bolt....
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Vinhead1957
« Reply #429 on: March 28, 2013, 09:57:41 AM »
They do have blind taps they are for holes that bottom out. Also you can make one out of the tap you have by grinding some of it off.
Offline SKTP
« Reply #430 on: March 28, 2013, 10:18:38 AM »
It's in there...Its not going anywhere...It threads in nicely. There's two bolts holding on the spigot. I'm guessing the crush-gasket acts as kind-of a split-washer, adding tension and then the clamp sits flush with the bolt heads. I don't see how this isn't completely fine...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #431 on: March 28, 2013, 10:50:20 AM »
Should be fine. There's always the option to use a helicoil later in the unlikely event that the current repair fails.
TAMTF...
Wilbur
Projects:
Offline Syscrush
  • Sold. :(
« Reply #432 on: March 28, 2013, 12:14:12 PM »
Glad you got it taken care of.  that picture looks like a triumph. :)
Offline Garystratos201
  • I have never been a
« Reply #433 on: March 28, 2013, 12:19:14 PM »
Congrats on the repair. Cutting off that small amout of threads shouldnt hurt at all. Nice thinking outside  the box.........Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline iron_worker
« Reply #434 on: March 28, 2013, 12:29:45 PM »
Ya I don't think Honda's safety factors were down low enough to make 2 threads matter that much. lol
IW
Offline SKTP
« Reply #435 on: March 28, 2013, 12:46:46 PM »
Do exhaust spigots commonly come loose or blow out in general?
(I had studs until now, as you know) Thank you for all you comments BTW...I can't believe that took so frickin' long...Exhaust test fit coming up!
Bookmark: http://www.newmotorcycleparts.com/electrical/connectors.html
« Last Edit: March 28, 2013, 01:30:12 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #436 on: March 28, 2013, 06:47:00 PM »
Congrats! I have no doubt that it will be fine and now you will be able to use that awesome exhaust.
Offline SKTP
« Reply #437 on: March 28, 2013, 07:46:49 PM »
Test fitting of headers :)
Need a slightly longer collector support but it's going to work :)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: 1978 CB750K - game on!
« Reply #438 on: March 28, 2013, 07:53:04 PM »
Man that is just tits.. I love those pipes.. A buddy of mine had them on his 71.. Been trying to buy the bike.. Collector rotted,but pipes look ok.. Bike had 72,000. Or 68,000 miles on itat end of 74 when I first saw it...
« Reply #439 on: March 28, 2013, 08:02:50 PM »
Bling Bling!
« Reply #440 on: March 28, 2013, 08:57:19 PM »
Wow! Those bends are great looking!
Offline SKTP
« Reply #441 on: March 28, 2013, 10:15:07 PM »
I'm in long beach too. Very cool
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #442 on: March 28, 2013, 11:11:07 PM »
Way cool.
« Reply #443 on: March 29, 2013, 10:45:09 AM »
Makes the effort worth it! I really like "sidewinder" style pipes...
TAMTF...
Wilbur
Projects:
Offline SKTP
« Reply #444 on: March 29, 2013, 07:12:27 PM »
Mocking up mounts (taillight too)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #445 on: March 29, 2013, 07:14:41 PM »
I'm just sick with nostalgia about those pipes!
Offline SKTP
« Reply #446 on: April 01, 2013, 06:58:01 PM »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Mcwilliams570
« Reply #447 on: April 01, 2013, 07:14:17 PM »
Those are nice pipes sir.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline iron_worker
« Reply #448 on: April 01, 2013, 07:37:09 PM »
I've never seen a header like that. Kind of like a 400F but so much more craZy!  8)
IW
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #449 on: April 01, 2013, 08:21:00 PM »
Wow! Looking nifty!
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
