Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Yep, that's what I figured...and have tried...Anyone successfully remove crazy-rusted-on-the-inside marker reflectors?They are soaking in PB-blaster as we speak
'78K 750 - 4 into 1 MAC exhaust with podsshimmed the needles 1mm and installed 135 mains.Starts, idles and runs great!
Quote from: SKTP on May 14, 2010, 11:27:56 AMShifter fork chunk?That little piece looks more like a bit of piston ring than shifter fork. The discoloration looks normal for a bike that has been ridden hard with a lack of oil changes. Most engine are not quite that dark on the inside. It looks like that sucker was run HOT. Not bad, per say, though.As for the tab on the tach gear, yes, just bend that down. The tab is there to keep the bolt from backing itself out and dropping into the valve train. To take off the head, you will need to take out the cam and cam towers. The valves and springs do not need to come out, but since you have it at that point, it wouldn't be that bad a time for an examination.
Shifter fork chunk?
