Author Topic: 1978 CB750K — Post 836 OIL PRESSURE - Seems bad :(  (Read 255027 times)
MRieck and 2 Guests are viewing this topic.
Offline SKTP
Re: The build slowly contines — 1978 CB750K - Assembly time - engine in frame
« Reply #900 on: January 21, 2016, 05:02:13 PM »
The female Alternator rubber "sheaths" are rock hard...I had to burn them with a lighter to get them to soften up for a second, then they returned to their previous rock hard state...I have used that crimper before...will have to acquired one again. Thanks everyone.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Restoration Fan
  • My wife will never call me
« Reply #901 on: January 21, 2016, 05:41:22 PM »
Sometimes also you can scratch the dirty color back a little.  If you have a steady hand you can shave off a poofteenth with a razor blade to find the color
Sent from my SM-G920I using Tapatalk
TIL an awesome new word!  Poofteenth is now my favorite measurement!
« Reply #902 on: January 21, 2016, 07:28:22 PM »
That is even better than RCH.. Specially when women ask what it means..
 Then they shake their heads, and say how thick is a Coyote hair  8)..and how do you know this .?  ?
Offline timbo750
« Reply #903 on: January 21, 2016, 07:57:04 PM »
A poofteenth is actually an official measurement is Australia, its 3/8 of a hair on a bees dick.
Offline SKTP
« Reply #904 on: February 14, 2016, 05:34:26 PM »
So the bike is coming together. I put the carbs on today....but after getting the push and pull cables on...it's not snapping back very well at all....and not like last time when it was the cable....it seems like the actual bar that turns and opens and closes is really grabby and stiff....is this common for carbs that have been sitting for 2 years in a plastic box? I figure I'll take them apart and clean them....last time I just slapped them on and they worked fine
« Last Edit: February 15, 2016, 09:31:30 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #905 on: February 15, 2016, 08:24:05 AM »
Do you guys have any opinions on sending carbs out for cleaning versus doing it yourself? This would be my first carb rebuild. I do not have an ultrasonic cleaner.
« Last Edit: February 15, 2016, 08:42:09 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #906 on: February 15, 2016, 09:27:40 AM »
Carbs suck. I hate messing with carbs. There's a couple of tricks to getting the PD carbs back together correctly. I've documented the choke linkage here:
http://forums.sohc4.net/index.php/topic,100352.msg1669248.html#msg1669248
Member Harisuluv is the local guru and has very good reviews. If you send them out, send them to him.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline edwardmorris
  • Youngish
« Reply #907 on: February 15, 2016, 10:12:37 AM »
+1 for sending it to James.
I invested in a US cleaner because I anticipated more than one build, and I also like to clean my cam towers and a few other things ultrasonically. They can be cleaned without one using various dips and such, but I'd hate to leave a possibility of having to redo it. IMHO, for a DIY clean, US cleaner is a must.
Offline SKTP
« Reply #908 on: February 15, 2016, 11:33:17 AM »
Email sent to james....
got these bad boys back on over the weekend...knuckles skinned...but I'm in love again
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #909 on: February 15, 2016, 11:45:46 AM »
Cool pipes, Chris.  Those clamps are interesting, too.
So, ready to ride??
Offline SKTP
« Reply #910 on: February 15, 2016, 11:52:13 AM »
I wish...I am close. I had my carbs cleaned once years ago...and 2 years ago I just put them on and they worked...this time however, they are sticking and not in the cable (last time cable routing caused some snap-back issues)...so I figure I'll send then out to get a proper cleaning...I am afraid to mess with them
The clamps were made by member 754...
« Last Edit: February 15, 2016, 12:20:07 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #911 on: February 15, 2016, 12:09:34 PM »
The clamps were made by member 745...
My CRs are due for an ultrasonic cleaning.  I just had the GL front inspected and resprung by Matt Wiley at Race Tech (for free!) but the carbs are not doing their normal job.  I'm taking them in to Jay's shop for a cleaning.  Stuck with the 550 for now.
PS My RC51 still needs a new home!
Offline SKTP
« Reply #912 on: February 22, 2016, 11:19:13 AM »
Sent my carbs out....finally got all the engine covers on.
It's so much heavier than I remember
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #913 on: February 22, 2016, 01:43:28 PM »
Yep.  Every time I ride my 750 after something else, I think the same thing.
Offline SKTP
« Reply #914 on: February 27, 2016, 05:56:28 PM »
2 quarts of oil are in the bike. I forget, do I just wait for it to drain into the main case (the oil tank is full currently) or do I have to pump it all through with the Kickstarter to get the remaining oil into the bike?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Desert-SOHC
  • It's old
« Reply #915 on: February 27, 2016, 09:03:26 PM »
I like to open the valve caps and squirt oil all over the cam and lifters before a first start, I just make sure my pint holding oil can is empty before I start it.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #916 on: February 27, 2016, 09:11:49 PM »
Get that sucka started, Chris, so we can go riding in LB!
Offline SKTP
« Reply #917 on: February 27, 2016, 10:01:13 PM »
My carbs are still out being cleaned and rebuilt....got the rear wiring finished today and got the rear brake linkage on....getting closer
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Bootsey
« Reply #918 on: February 27, 2016, 10:16:35 PM »
Man, those headers & clamps are all kinds of awesome.
Offline SKTP
It runs
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Congrats, yeah oil on top end is best...the oil tank shouldn't drain down to the sump or you have issues that need addressed.
It runs
As you know I was one of the first owners of a set of Triple A pipes like yours. (see my avatar, ca 1971). How does it sound?
Ditto on the clamps!  ;D
BTW: #3 makes a nice case guard, don't ask me how I know.  ;)
Offline SKTP
This is the it running for the very first time this rebuild.
Strangely, it was had to start a few hours later...but it did start
I put it through all the gears while on the center stand.
Things to do: Button up the bird's nest, front brakes, front fender, speed/tach cables, new tires would be a good idea...
MCRider...I don't understand what/who #3 is?
http://iconosquare.com/p/1205374959198561631_464507968#sthash.OdInPcra.dpuf
« Last Edit: March 14, 2016, 10:16:40 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline BPellerine
Re: The build slowly contines — 1978 CB750K - Running VIDEO link added
« Reply #923 on: March 14, 2016, 10:35:24 AM »
sounds good!think mc rider meant no 3 pipe.billp
1978 CB 750K ard and webers
another anfob
Offline SKTP
« Reply #924 on: March 14, 2016, 10:46:21 AM »
Ah that makes sense....I'm a little slow this morning...day light savings and all
So #4 should be rider's right? I have the #4 plug wire rider's left
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
