Author Topic: 1978 CB750K — Post 836 OIL PRESSURE - not good  (Read 247758 times)
Re: 1978 CB750K — It never ends!
« Reply #1200 on: October 11, 2017, 07:52:19 PM »
 Just give yourself some time before selling I dont think you should.
I think the solution may be fairly simple.
 Btw what gaskets are you using, and dry, or ?
Offline calj737
  • I refuse...
« Reply #1201 on: October 11, 2017, 09:08:28 PM »
Re-torque of the head will solve the weep. Simple as that.
Offline SKTP
« Reply #1202 on: October 11, 2017, 09:24:11 PM »
This round I used all HONDA OEM gaskets. Yes, even the head. I didn't copper spray them. I wish re-torquing was simple. No frame kit.
I think going from the CB (first bike ever) to the Ducati (lots of highway miles), then a break from riding (about 2.5 years), then back to the CB has just made the CB feel sketchy compared to the Ducati on LA freeway riding.
« Last Edit: October 11, 2017, 09:27:16 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1203 on: October 11, 2017, 09:50:34 PM »
I have had a weeping head gasketmthat goes away after a bit of riding.
Ditto for my oil pressure sender..
Offline SKTP
« Reply #1204 on: October 17, 2017, 11:46:04 AM »
I was cleaning/organizing the garage and found the speedo and tach that came on my bike when I first bought it. 71191 miles!!!! I don't think I remembered that part of all this... And that's before it was my daily driver for 2.5 years!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #1205 on: November 05, 2017, 10:58:49 PM »
Ok...my main shaft seal is leaking too much...I will be pulling and replacing at the next oil change. Should I do the frame kit at this time...and if so, which one is best?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline calj737
  • I refuse...
« Reply #1206 on: November 06, 2017, 03:36:45 AM »
If you can weld, then get a weld-in. If not, get Frank’s. Cut the tubes for the frame kit before removal to aide in getting the motor out. Then complete the installation while out. Easy.
Offline SKTP
« Reply #1207 on: November 06, 2017, 02:18:13 PM »
Well I am going to think about it...might just pull the motor conventionally because I need to change out the main-shaft seal (didn't seat properly)
That's it right? #10 It is behind the points
« Last Edit: November 06, 2017, 02:22:29 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1208 on: November 06, 2017, 02:37:04 PM »
Yeah, the tube kit won't help much if you gotta split the cases anyway. But its nice to have for top end work.
Helps a little when the tubes are gone to get the whole engine back in.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 1978 CB750K — It never ends! (Round 4 coming soon)
« Reply #1209 on: November 06, 2017, 04:54:23 PM »
I've read reports of that seal being replaced without splitting the cases. Yes, there is a lip on the inside of the seal, but the process involved grinding a bevel on the outer edge of the case opening to get the lip started into the case and using the advancer shaft with washers and a collar to press the seal into place. A little permatex anaerobic sealer around the opening would also help provide some lubrication. If it fails you're only out the cost of the seal. If it works you saved a lot of work.  8)
If you're concerned about damage or over stressing the advancer shaft (as well you should be) you could use a plate bolted to either the points cover bolt holes, or maybe the points plate bolt holes. An old points plate could even be "pressed" into service as a backing plate for pressing the seal into place. The search function for the site is now functional again so I would expect the relevant thread(s) could be found.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline SKTP
« Reply #1210 on: November 06, 2017, 05:00:07 PM »
I did ask this question before and did search and did find the member that replaced the seal without splitting the case.
http://forums.sohc4.net/index.php/topic,167112.msg1933186.html#msg1933186
I forget if it was in PMs or where it is. But I was told the seal eventually started leaking again and they split the cases and replaces the seal for the OEM one.
This will be my 4th case-split but my first Bottom-Only split so I think I feel pretty good about it.
I will need: the Oil-seal, Trans gasket, Clutch gasket, oil pan gasket, and I think that's it?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1211 on: November 06, 2017, 05:09:45 PM »
Ahhhh.... I was not aware of the follow up regarding the eventual failure. Yes, it does seem as though you have had plenty of practice now, you'll soon be able to split the cases in your sleep.
Or was that nightmares?  :o
Hang in there, you've come this far!  8)
TAMTF...
Wilbur
Projects:
Offline SKTP
« Reply #1212 on: November 06, 2017, 06:00:28 PM »
It is not even THAT bad of a leak...but...it leaks directly onto my exhaust pipe and at night, it looks like I am steaming like a hot tub on a cold night.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1213 on: November 06, 2017, 06:55:58 PM »
I agree that you can probably flip it over and just disassemble the cases.
Offline 01Thomas
« Reply #1214 on: November 11, 2017, 07:01:10 AM »
Don't forget the alternator gasket.
Offline SKTP
« Reply #1215 on: November 23, 2017, 05:05:59 PM »
Drove 88 miles or so today. From Long Beach, up the 710 to the 405 to the 110 to all over LA...across Santa Monica BLVD to Pacific Palisades...down PCH...to El Segundo...over to the 405 and home...there's still leaks....the suspension leave a lot to be desired...but it was a fun day...oh yeah, top speed via GPS: 83.7mph
« Last Edit: November 23, 2017, 05:18:07 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #1216 on: December 09, 2017, 10:31:15 AM »
Great photo! Bikes not bad either ;)
Offline SKTP
« Reply #1217 on: December 21, 2017, 06:51:20 PM »
Strange...seems like multiple recents post in this thread have been deleted?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #1218 on: December 21, 2017, 07:06:24 PM »
Site crashed. Last good backup was Dec10th.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline JoeCooley
« Reply #1219 on: December 21, 2017, 07:07:09 PM »
I will take a pic of my breater setup tmrw.
Offline Tintop
« Reply #1220 on: December 21, 2017, 07:14:49 PM »
Ok, so it's not just me being off line for a couple of days.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline USMC5811
« Reply #1221 on: December 22, 2017, 12:58:27 PM »
Good to know - I thought all the moderators were mad at me...again
Offline JoeCooley
« Reply #1222 on: December 23, 2017, 11:04:48 PM »
Well I forgot to get the picture for you. Now it's back together. I had actually wrote out a long post about how mine is setup. I guess I'll do again. Haha.
Ok so 3 hoses. Top, middle, and bottom. Top goes from separator to the airbox, middle is from the valve cover to separator, bottom is a drain. The bottom may have a little peacock on it to drain the oil that collects. Mine just has a bolt in it. I had my air/oil separator apart recently and stuffed it full of steel wool to catch the vapors. I don't have the factory air box so I just vent the top hose by the carbs. There is also a hose from the oil tank to the transmission. I believe this a pcv vent also.
Hope this helps. I remember you asking about a diagram for the system earlier in the thread. Maybe it's gone now?
« Last Edit: December 23, 2017, 11:10:05 PM by JoeCooley »
Offline SKTP
« Reply #1223 on: January 16, 2018, 12:01:48 PM »
Well, here's the new plan.
I was going to get an RC51 and give the CB a rest, but instead, I have decided to pay somebody to rebuild my motor. The last ride I went on the bike really started leaking and it is smoking out of the top breather way too much. So since I will have the motor out for the 4th time, why not throw this in there?
http://www.dynoman.net/bikepages/sohc/packages.html
Now I need to figure out pistons. Are 78K piston more like F bikes?
« Last Edit: January 16, 2018, 12:39:28 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline JoeCooley
« Reply #1224 on: January 16, 2018, 06:55:58 PM »
Here's a post from a while back to explain things. http://forums.sohc4.net/index.php?topic=6742.0
Essentially the 75-76F & 77-78k had the same pistons. A very slight dome. The main difference from these engines and the older engines is in the cylinder blocks. Honda added the big oil o-ring things to help with leaks. F2/3 pistons are a breed all their own. Those pistons with a K head will result in hi compression due to the smaller chambers of the K's.
