Author Topic: Carbtune issues  (Read 10901 times)
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: Carbtune issues
« Reply #100 on: April 07, 2010, 02:12:09 AM »
I think that if they are not new and they are on backwards, that is worth checking. Since you had so much trouble getting them on...
Good thought, but I happen to have 4 new 16211-323-000 rubbers in readiness to reassemble my 550F and they are the same depth from either end. There doesn't appear to be a front & back so to speak.
Comparing my old ones with the new all I can say is I'm really glad I got newbies. The 'ridges' inside the rubbers which engage on the grooves of the manifold & carb bodies virtually don't exist on my old ones. I've had them off a couple of times over the years, but not sure how many times by PO.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline cookindaddy
  • I sure love this bike!
Re: Carbtune issues
« Reply #101 on: April 07, 2010, 03:59:25 AM »
I see. Mine is a 750K with what looks like the same Keihin carb and my insulators are definitely different at both ends. The head end is thicker rubber and slightly smaller ID. They are possible to put on backwards (I did with one by mistake) but it is extremely difficult, like he said it was. I'm looking again at the pics he posted way at the beginning of this thread and what he is using looks to be different at both ends? Anyway, I made my point. Hopefully he will figure out whatever it is that is causing his vacuum leak.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Frostyboy
  • Circa 1951
Re: Carbtune issues
« Reply #102 on: April 07, 2010, 04:07:24 AM »
Aha, maybe that's the answer Cookindaddy. Perhaps they're the wrong rubbers on there ???
We haven't met yet.
[CB550F1]
Offline cookindaddy
Re: Carbtune issues
« Reply #103 on: April 07, 2010, 04:10:46 AM »
Frostyboy: Why don't you post a pic of your new official parts for him? So he can see what he is supposed to have? The ID at both ends is the same? You mentioned the depth, but not the ID.
Offline Brian G
Re: Carbtune issues
« Reply #104 on: April 07, 2010, 04:59:08 AM »
This is better than a movie  ;D ;D
My understanding is that the '77 & '78K carbs are different. I have mine off right now, and when fitting the insulators back onto the carbs was surprised to find that they were a very loose fit. I then realized that I was fitting the head end of the insulator to the carb rack.
The fact remains, there must be vacuum present for the thing to run, so it must be able to be read on your gauges. Check the holes are clear anyway.
There's nothing for the gauges to read! All the air for combustion is being drawn into the engine from downstream of the sync ports so there isn't enough vacuum at the carbtune to lift the indicator columns. What little fuel/air mixture is being drawn through the carbs is enough for a (crummy) idle but is so lean it causes popping & backfiring when the load goes up.
Stu's pictures tell it all. And what else in the induction system would affect all four gauges?
Hth,
Brian
« Last Edit: April 07, 2010, 05:03:24 AM by Brian G »
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
Re: Carbtune issues
« Reply #105 on: April 07, 2010, 05:09:07 AM »
Hth,
Brian
  Stu's pictures tell it all. I agree.  ::) And what else in the induction system would affect all four gauges? Maybe from time to time the laws of physics cease to exist in CB550's. ;)
Re: Carbtune issues
« Reply #106 on: April 07, 2010, 08:09:55 AM »
I think I've got a HEAD ache, anyone know a good HEAD doctor?  ;D ;D ;D ;D
Sam. ;)
Offline Bob Wessner
  • "Carbs Suck!"
Re: Carbtune issues
« Reply #107 on: April 07, 2010, 08:51:45 AM »
Might I direct you to the healthcare thread?  ;D
Re: Carbtune issues
« Reply #108 on: April 07, 2010, 09:34:02 AM »
Heads suck as much as carbs Bobby ::) ::) ::) for some :D :D :D :D
Sam. ;D ;)
Offline Nikkisixx
Re: Carbtune issues
« Reply #109 on: April 07, 2010, 10:08:37 AM »
Sam. ;)
I don't always understand your accent Sam, but it sounds like this is where your HEAD is:
[youtube=425,350]<object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/youtube]
Re: Carbtune issues
« Reply #110 on: April 07, 2010, 10:16:32 AM »
The English sence of humor Nik  ;D ;D ;D I'd rather be in NC though  ;)
Sam. ;)
Offline Nikkisixx
Re: Carbtune issues
« Reply #111 on: April 07, 2010, 10:27:00 AM »
Sam, the weather is good and the drag racing is better!  8)
Re: Carbtune issues
« Reply #112 on: April 07, 2010, 10:31:27 AM »
That's why I'd rather be there, ;D ;D and the nice girls ::) ::) ::)
Is there much bike racing going on at Piedmont these days, don't here much about the place since Mike sold it. :(
Sam. ;)
« Last Edit: April 07, 2010, 10:39:25 AM by SamCB750A »
Offline Nikkisixx
Re: Carbtune issues
« Reply #113 on: April 07, 2010, 11:12:22 AM »
Sam, I've only been here in the Carolinas for 18 months, but have been to Farmington, Z-max, and Rockingham.  We've some great dragstrips here! Haven't made it to Piedmont yet - I'll put it on the list  :)
Re: Carbtune issues
« Reply #114 on: April 07, 2010, 12:08:46 PM »
To clear up confusion about the couplers, I offer these pictures and some dimensions.
The couplers (and manifolds) for the PD carbs are significantly different from the earlier style and are used on K model CB550 in 77-78 model years (US models)
In the 1st picture, the left is the earlier style and right is the PD style.
77-78 couplers are shorter in length and wider in width.  They also have two molded ridge lines which orient toward the carb side connection.  The second picture is a snap of my 78 CB550K, showing installed orientation. (My 78 runs, btw.)
The early couplers have the same internal dimension for both carb side and manifold side.
The PD couplers have a different internal dimension on each end.
For the couplers I have in the parts bin, they measure 33.9 mm on the ridge lined end and 31.5 mm at the other end.
These are, however, old and hard and may have shrunk.  So, those dimensions are only ball park.
Re: Carbtune issues
« Reply #115 on: April 07, 2010, 11:24:46 PM »
Seems they have bikes at least once a month, only 1/8 mile but a well prept track.
http://www.piedmontdragway.com/schedule.html
Sam. ;)
