Author Topic: question about carbs compatibility for CB550  (Read 521 times)
Offline thunderzy
« on: April 06, 2010, 03:35:35 PM »
I would like to know if '78 CB550 carbs will fit on a '75 CB550.
Thanks
Zack
Offline lynchj
  • Life is short ...go for a ride now
Re: question about carbs compatibility for CB550
« Reply #1 on: April 08, 2010, 01:47:52 PM »
This is the wrong forum for this question, it probably should be in the SOHC/4 Bikes forum. I wish I could give you a good answer but I'm not sure if they would or wouldn't fit.
my CB500 build thread   http://forums.sohc4.net/index.php?topic=54143.0
Other toys: 98 YZ125, 70 MGB, 99 Camaro
« Reply #2 on: April 08, 2010, 03:48:09 PM »
He already asked in the tech forum, and apparently didn't like the answer.
So, ....how about this answer?  Yes, if you change enough other stuff on the bike?  It is not a direct swap, but work hard enough and you can make them work.
http://forums.sohc4.net/index.php?topic=68512.msg756513#msg756513
