Author Topic: Smoke from top end (help me style thread)  (Read 695 times)
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
« on: April 08, 2010, 05:17:46 AM »
So, there is smoke coming out of my breather tube. What would cause it? Here's my situation.
I've been having a hailstorm of a time getting my carbs set up correctly on my 78 cb550k, particularly the idle. (Rebuilds and sticky floats.) So, currently, it idles poorly, but I did go through and do cam, tappets, timing, etc for my spring tune up. Since then I've also put on a new carburetor but it's not the 69a. I can't think of the number stamped on there. Anyway, after driving a while smoke will come out of my breather tube... badly set valve clearances? Burning oil? Something completely different? (10k motor so low-ish miles.) TIA
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Offline 333
  • Time for change
Re: Smoke from top end (help me style thread)
« Reply #1 on: April 08, 2010, 06:29:55 AM »
Some of this is normal,but...
Is it smoke, or could it be steam?  Water sometimes condensates in the crankcase and will vent as steam when the motor is hot.
My other thought is; what is your compression?  If you have a bad exhaust valve seal, the escaping hot gases may be burning off the oil.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
