So I was checking to see if the tensioner rod was free - had my screwdriver in the hole on the rod, and turned the crank back and forth. I got and very slight up and down movement, which I assume means it's free. But I was curious, just how much movement should be expected here? And when using the engine running/push down method to adjust, again how much movement will there be?
