Author Topic: 1977 cb750f2 (915cc)  (Read 295235 times)
Offline tweakin
  • tear down
Re: 1977 cb750f2 seats done 12/12/10
« Reply #275 on: December 11, 2010, 07:42:27 PM »
Thanks for the compliments on the seat, I think the gel was a good move to.
« Last Edit: December 12, 2010, 02:33:06 PM by tweakin »
Offline wannabridin
  • Patience made me a
  • -Garrett
Re: 1977 cb750f2 seats done 12/11/10
« Reply #276 on: December 11, 2010, 09:40:59 PM »
Looks GREAT! If you dont mind my asking, what did something like that set you back?  This is very similar to what I want to do!
Offline HalfFastMoto
« Reply #277 on: December 11, 2010, 09:58:25 PM »
Nice!  MAC's in Ballard - I'll have to check them out.  Was toying with the idea of doing my own cover but yours turned out great!
-brad
Better HalfFast than HalfA$$ed
The appropriate number of bikes is "1" more!
Offline tweakin
  • tear down
« Reply #278 on: December 12, 2010, 06:59:20 AM »
Steve at Mac's does some nice work.  Forum member rat400f recommended Mac's to me.
Offline HedNut
  • Underwater Basket Weaving
« Reply #279 on: December 12, 2010, 07:10:30 AM »
That's a sexy piece of bum pad there!  Excellent touch to the bike!!
  • Be careful you might get a
« Reply #280 on: December 12, 2010, 07:36:54 AM »
Nice! Funny thing is I was just thinking about asking if it was done yesterday. We drove by Mac's yesterday and it reminded me you had a seat there. Steve did and excellent job on your seat too. That guy really knows his stuff. Congrates!
Offline tweakin
  • tear down
« Reply #281 on: December 22, 2010, 05:26:32 AM »
So I got the dyna 2000 ignition set up and it was a breeze.  With the new ignition and carb sync the bike idles nice and smooth and throttle response it 10X better than it was previously with the older dyna ignition.  I don't think I ever had the bike timed properly.  I am know on vacation for the rest of the year so I will have time to finish up the rest of the bike, I hope.  New pics and video soon.
Offline hapakev
  • Your Standard
Re: 1977 cb750f2 pipe fit
« Reply #282 on: December 23, 2010, 09:00:15 AM »
I am using a complete 1977 Gl1000 front end (trees, lowers and tubes and brakes)  I used a taper bearing conversion kit from www.allballsracing.com
https://www.allballsracing.com/index.php/99-3511-5.html
https://www.allballsracing.com/index.php/99-3512-5.html
I am using a 1976CB 750 front hub with 1977 GL1000 brake rotors and 1977GL1000 speedo drive and speedo drive adapter from forum member http://forums.sohc4.net/index.php?topic=76835.0
I am using the axle from the 1977 GL1000 front end.
Everything bolted up nicely with minor adjustments made to the wheel spacers.
The rear wheel is from a 1976 cb750f with a stock 1977 cb750f brake rotor.   This all bolted up well with minor modifications to the spacers.  I don't have the exact size of the spacers, sorry.
I initially tried to use my stock 1977 cb750f tress and lowers with the 76f front hub but ran into issue.  The 77 f trees are too narrow for the spoked with rotors and the 77f rotors were the incorrect bolt pattern for the 76 hub.
I am not much of a writer so I help this helps some.
Why didnt you use the GL front hub/rotors/speedo drive all together?
also, which all balls steering bearing is the top and which is the bottom?
Thanks-I'm using the exact same front end/F3 bike combo.
Smoking Jack
1978 CB750F(ish)
Offline tweakin
  • tear down
« Reply #283 on: December 23, 2010, 09:16:28 AM »
Essentially I did use all GL parts, the 76 750 hub is the same part number as the GL.  I started of thinking I could do the spoke conversion and still use my 750f front end but it is too narrow.  I already had a bunch of different 750 and gl parts so I used what I had.  The easiest way would be using all GL parts.  I used the machined speedo drive from forum member since I already had it and it is so nice.  Once you get the bearings you will know which one is the top and which one is the bottom because of the circumference.  The bottom is bigger to fit over the stem that widens at the bottom of the tree.
Hope this helps.
Offline tweakin
  • tear down
Re: 1977 cb750f2 Updated pics 12/23/10
« Reply #284 on: December 23, 2010, 03:26:46 PM »
Ok, so the bike is close to complete, for the second time.  I still need to do a shake down run, but I can finally see the light at the end of the tunnel.
« Last Edit: December 23, 2010, 03:54:27 PM by tweakin »
« Reply #285 on: December 23, 2010, 03:37:30 PM »
Very nice mate......Just in time for Christmas..... ;)
Offline brandEn
« Reply #286 on: December 23, 2010, 04:14:34 PM »
Looks killer Tige! How does that seat fit?
Offline Zaipai
    • My Home page
« Reply #287 on: December 23, 2010, 04:20:31 PM »
No lie, that looks stellar!
Nice job!
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #288 on: December 23, 2010, 04:48:26 PM »
Excellent!
 ;D ;D ;D
-brad
Offline tweakin
  • tear down
« Reply #289 on: December 24, 2010, 05:22:30 AM »
Thanks guys, I am stoked!    The seat fits well.  I had to do some minor modification but now it fits like a glove.
Offline Gearheadgreg
  • Jamestown Rhode Island
« Reply #290 on: December 24, 2010, 06:28:23 AM »
WOW!!! now that is tasteful!! read through your build here,,looks like a 10 on the scale.
2001 Honda Supercharged Valkyrie   <iframe width="480" height="360" src="http://s1218.photobucket.com/user/meloafer/embed/slideshow/"></iframe> Just having some fun
Offline hapakev
  • Your Standard
« Reply #291 on: December 24, 2010, 11:03:59 AM »
First off:  Beautiful Freakin Bike!! Exactly what I want to build, pretty much  ;)
Hope this helps.
I was mostly curious about the front rim, Did you use the cb750 rim to match?  I'm struggling with that right now, use the 17" goldwing rear rim on the cb750f hub, or the 19" cb750 rim on the GL front hub, so they match.
Smoking Jack
1978 CB750F(ish)
Offline tweakin
  • tear down
« Reply #292 on: December 24, 2010, 01:55:54 PM »
Thanks....
I got new aluminum Sun rims but went with the same size as a stock 77 cb750f.  19 front and 18 rear and had Buchanan's cut the SS spokes.  The GL and 76 750 front hubs are the same hub.
Hope this helps.
Offline wannabridin
  • -Garrett
« Reply #293 on: December 24, 2010, 02:35:56 PM »
Looks GREAT!!  You took my keychain tho, I had that one before my last move, seems to be lost somewhere tho!
Offline hapakev
  • Your Standard
« Reply #294 on: December 24, 2010, 02:49:15 PM »
Thanks man, i might end up using the 76F hub/rim with the GL rotors, so it matches the 76F rear wheel/rim
Great Inspirational Build.
Smoking Jack
1978 CB750F(ish)
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #295 on: December 24, 2010, 05:21:34 PM »
NICE !  :D
music
Offline joshuanagao
« Reply #296 on: December 24, 2010, 09:48:16 PM »
Tweakin your bike is so sweet!  The quality of your work is awesome!
Offline tweakin
  • tear down
« Reply #297 on: December 25, 2010, 07:43:33 AM »
Yah, great keychain isn't it.  Wife says it doesn't dumb, because if you remove before flight the bike won't run...  Guess she is right, lol.
« Reply #298 on: December 25, 2010, 10:08:02 AM »
Way too nice to ride  ;D
Offline tweakin
  • tear down
« Reply #299 on: December 25, 2010, 11:17:12 AM »
Bikes are never too nice to ride..
