SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
cb400f chain upgrade
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: cb400f chain upgrade (Read 2081 times)
kajtek
Hot Shot
on:
April 09, 2010, 05:10:42 AM »
a newly acquired cb400f is in need of new chain/sprockets... i always prefer to upgrade to something modern in instances like this so the obvious choice to me is an x -ring. using the search function i see that im looking at 96 links, and that 530 (which im assuming the current chain is) in an x ring is a little wide so 520 would be best. found this which isnt too expensive:
http://www.intobikes.co.uk/products/000649/Afam_520_Pitch_-6_XRR_Heavy_Duty_X_Ring_Chain?src=fro&highlight=005294
so just need to work out some sprockets in 520. not been able to find cb400f specific 520 sprockets. any ideas on somewhere europe/uk based that has them?
one thing i was considering... was to get the standard sprockets and have someone local machine them to the right width. cant imagine its too difficult. please let me know if this is a terrible idea...
thanks
ashley
Logged
1978 honda cb400f supersport
kajtek
Hot Shot
Re: cb400f chain upgrade
Reply #1 on:
April 09, 2010, 05:41:41 AM »
might have found sprockets here... will contact them and see wether they will fit a cb400f..
http://www.d-mengineering.co.uk/store52/agora.cgi?product=Sprockets&xm=on
ashley
Logged
fasturd
Hot Shot
Reply #2 on:
April 09, 2010, 06:01:13 AM »
I have a 530 x ring on my 400F and no clearance issues.
Maybe some are too wide but mine is clearing no problem.
Logged
13 in the garage and counting...
Link to my link...
http://forums.sohc4.net/index.php?topic=58422.0
kajtek
Hot Shot
Reply #3 on:
April 09, 2010, 09:16:07 AM »
interesting... what brand chain do you have?
thanks
ashley
Logged
Bodi
Really Old Timer ...
Reply #4 on:
April 09, 2010, 05:00:14 PM »
The clearance problem is mostly at the rear left shock. Larger diameter shocks with long springs - Mulholland for example - will interfere with a wider chain. It depends on where the adjuster rings is located. Stock-like shocks with shorter springs should be fine.
Logged
kajtek
Hot Shot
Reply #5 on:
April 09, 2010, 05:17:30 PM »
i see.. interesting about the shocks. d m engineering do front and rear sprockets in 520 that fit (the rear sprocket requires spacers), but the rear is an alloy sprocket... so not sure yet. if the 530 fits ok i may just go with that although i do like the idea of a lighter chain.
530 chain:
http://www.intobikes.co.uk/products/000081/Afam_530_Pitch_-6_XRR_Heavy_Duty_X_Ring_Chain?st=mn
not too expensive if it lasts a long time. whats the consensus on a 520 conversion. is it worth the extra fuss?
ashley
Logged
fasturd
Hot Shot
Reply #6 on:
April 09, 2010, 09:57:50 PM »
I would have to think a 520 would be fine ...Sport bike guys do it all the time with WAY more HP than a 400 will ever have. I had no shock clearance issues and I am using the stock chainguard and aluminum Konis. I will get into the shop and figure out which chain it is. I thought the x ring was proprietary to one mfgr?
Logged
Link to my link...
brandon
Enthusiast
Reply #7 on:
April 10, 2010, 12:56:48 AM »
I have a 530 X-Chain on my CB400F also, with the Konis and no issues with clearance.
Logged
kajtek
Hot Shot
Reply #8 on:
April 11, 2010, 07:56:12 AM »
cool, will keep looking to see if i can find a 520 steel rear sprocket, at least i know the 530 x will fit.
many thanks
ashley
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
