ok again with the sorrys for so many posts... It is just driving me nuts, and I think maybe after a long long night, I've figured it out. Below is a picture of what my points look like. I daresay that this replacement set of points came with a viewer window on the bottom, but our bikes have the view at the top, so this was mounted with the window at the top. Thus showing 2.3 T when in fact 1 and 4 are at tdc. I traced the combustion sequence in my head with the tappet covers off and the plug removed so i could folow along with where the piston was at the time, and it went smoothly. (intake and exhaust are loose and piston is at tdc, intake goes tight piston moves to bottom, intake gets loose, piston moves up, points for 1.4 make contact, piston moves down, then back up, exhaust gets tight as it moves up, then gets loose again and back to step one with both tappets loose and piston at tdc) This to me means that the aftermarket points and its viewer window are just screwed on to show the wrong marks. Thoughts?
