Author Topic: Could you? (Airboxy stuff.)  (Read 452 times)
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
« on: April 13, 2010, 01:03:58 PM »
So i was looking here http://forums.sohc4.net/index.php?topic=63092.0 and liked the simplicity behind the way he made an airbox/airfilter. Could you do one better and cut the entire back off (Or, an appropriate amount) of an airbox and put a filter medium over the hole? You should still get the drop in air pressure inside the box... but you wouldn't see the air filter at all. You could probably do this with the filter material on a stock filter, if you used a stock filter, you'd have the correct amount of surface area to work with. Thoughts?
« Last Edit: April 13, 2010, 06:38:29 PM by Tretnine »
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
