Author Topic: Lightning Alternator  (Read 5135 times)
Re: Lightning Alternator
« Reply #25 on: April 15, 2010, 09:53:49 PM »
I prefer to lighten the crank and run a balanced, late model rotor.
Mike,could you please elaborate? Later 750 of different rotor?
« Reply #26 on: April 15, 2010, 09:55:30 PM »
I wanna run a ridiculously bright headlight.
Look at HID conversion then because the Honda charging system already runs at about its limit, more powerful headlight may give you charging issues.
« Reply #27 on: April 15, 2010, 10:20:07 PM »
Mick, I found a K7 rotor was several lbs lighter than my K1 rotor. Sorry, I can't give accurate numbers, but it was definitely lighter. Also, I was reluctant to turn either rotor, as I had no way to balance, so I ran the K7. Don't know when Honda went to the lighter rotors, but I can verify that K7 was lighter than K1....
Scott
« Reply #28 on: April 15, 2010, 10:25:19 PM »
They dropped the flange off, in 73.
 I think Mike means take the weight off the crank, rather than the rotor....not an option if we are not splitting cases.
 I have run with no rotor at times, on my 836 we welded the oil hole in the crank..
« Reply #29 on: April 15, 2010, 11:51:42 PM »
I have a lightened RC crank already, i was just after a lighter rotor that would charge the same or maybe better than the stock alternator as i want to run fuel injection. I will run LED winkers and tail light and HID headlight and i would also like to retain the electric start if possible.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #30 on: April 15, 2010, 11:52:48 PM »
Will the cycleX one not work for you then?
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #31 on: April 16, 2010, 08:15:02 AM »
I have a couple in my basement, with and without the flange.  I also have a really accurate scale.  I'll try to remember to weigh them and post the results.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline MattFreeman
  • What Have I Done?
« Reply #32 on: April 16, 2010, 02:29:17 PM »
Thanks for the good feedback, guys.
« Reply #33 on: April 16, 2010, 03:39:18 PM »
Are they not "kick only"? I will have to go to their site and have a look..
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #34 on: April 16, 2010, 04:29:38 PM »
No! I had to remove my kick on the Tracy due to the rear sets. I'm only electric start now only.
 I went one bulb size down from stock on the headlight and it works like a charm now.
Give him a call if you have any questions. Oh yeah, Overseas...whatever. ;D
  • Tuck
« Reply #35 on: April 18, 2010, 12:17:18 PM »
So here's what I got:
Both are stock and not modified in any way.  I left in the little springs and weights and the retainer for these for each.
K2: 7.0765 lb  This one has the flange.
K4: 5.8430 lb  This one is without the flange.
A difference of about 1.234 lb (that should be an easy number to remember  :)).
1974 CB 750
1966 Black Bomber
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #36 on: April 19, 2010, 01:51:07 PM »
Ignore my earlier post. Fricken dead battery in Vancouver Yesterday!!!  ::)
Offline Ayrity
« Reply #37 on: April 19, 2010, 01:56:48 PM »
what if you replaced a bunch of the bulbs with leds? there are easy cheap kits online with circuit boards included. less power, longer lasting lights!
1976 Honda CB550k
« Reply #38 on: April 19, 2010, 07:55:12 PM »
So cant you jumper/push it to start.?.
Mine starts on 6 volts or less..
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #39 on: April 19, 2010, 08:08:44 PM »
No Kick. Had to remove due to rear sets :P
Charged it overnight.
Slept on a friends couch, got home this afternoon.
You can't leave your bike running for 2 hours on a ferry ;D It would have died anyway.
« Reply #40 on: April 19, 2010, 08:23:06 PM »
I know it has no kick. They do push start scarily easy
Offline MattFreeman
  • What Have I Done?
« Reply #41 on: April 20, 2010, 05:42:07 PM »
Lazy link? :-* :-*
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #42 on: April 21, 2010, 06:13:44 AM »
hey Mreick or anyone else who knows...
can you "slightly" lighten a crankshaft?  i'm going to have it balanced, but is it possible to take off a little bit to help with the revs and everything?  then you still get some of the "stored" momentum of a heavier crank, but some of the pep of the lightened one...  this coupled with the lightened alternator would give you a streetable ride that would rev quicker, right??
« Last Edit: April 21, 2010, 08:56:14 AM by wannabridin »
« Reply #43 on: April 21, 2010, 07:22:41 AM »
You can cut off varying amounts.
 If yours is 73 & later it is lighter than a 72. If you lighten it too still use e-start it is  not fully lightened.
 Your riding style has a big influence on how much you should be cutting off. How much/often, do you take it to or past stock redline?
Offline Laminar
  • Retsam
« Reply #44 on: April 21, 2010, 07:26:26 AM »
Offline wannabridin
  • -Garrett
« Reply #45 on: April 21, 2010, 08:56:00 AM »
haha, i thought the same thing when i first read the lightning part laminar!!
754, i like to ride to the limits of the motor without doing any damage.  so i'd say i do a decent amount of powershifts when i'm really hammering it!  other than that, i ride up to about 8k rpm or so.  what are your recommendations?
« Reply #46 on: April 21, 2010, 09:45:42 AM »
If you like revving, you will probably like it, moreso if you spend a lot of time over 5K
 If you like taking a 2 week trip, with a vetter, 2up, & lots of gear..you probably wont like it.
 If you are likely to gtab a handleful of R's, and are not afraid to dump/sliiiipppp  the clutch, its probably for you.
 If racing off the line and you bog, you can get revs back quicker.
 I would not run my 836 without one.
 I have also NO rotor, that is a bit different animal.
Offline MattFreeman
  • What Have I Done?
« Reply #47 on: April 21, 2010, 04:24:27 PM »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #48 on: April 21, 2010, 08:38:29 PM »
Thought I would call Cycle X today and actually ask what the output is on their lightend alt.
No one answered the phone. Suppose I will try later.
Offline wannabridin
  • -Garrett
« Reply #49 on: April 22, 2010, 06:14:14 AM »
i do like to stay in the powerband with the bike, as i like to ride as aggressively as i can!
it's a one up only, i'm selfish and don't care if a girl want's a ride.  my dad's vtx1300R is the bike i use for long hauls.  and i'm working on a family friend to sell me his old gl1100...  THAT would be good for a trip or two!   ;D
i'll still need my rotor, so i'm sure it'll still be tame enough!  i guess i'll go with take a little off but balance it and the rotor.  help rev's but still keep it somewhat "friendly"
