Author Topic: '80 Coils in a 74?  (Read 2055 times)
Offline Bryan Boyle
  • SOHC4 #47 ...one of the Old Pharts
    • The Other Hobby: Restoring Lotuses
'80 Coils in a 74?
« on: April 25, 2005, 06:55:54 PM »
just checking, because IIRC, this may already be answered...but, are
coils from an 80 750 (which are nice because you can replace the plug wires
rather than on the earlier ones which were moulded in place...) able to
be dropped in to a 74?
Thanks....:)  Just won a set off the 'bay..so, if not...will be sending them
out to someone here....:)
Bryan
SOHC4 #47
Proud member since 1994, active on and off
Commercial Pilot/Flight Instructor-Instrument/A&P
Morrisville PA
'63 CA95, '64 CA77, '73 CB350F, '73 CB350F, 2 Lotus Europas and Lots of Parts All Over The Place
Offline Dennis
Re: '80 Coils in a 74?
« Reply #1 on: April 25, 2005, 07:17:06 PM »
I have heard of some people doing this.
The nice thing about them as you say is that the wires can be replaced. The primary impedance however is lower (than stock), and this results in a higher current flow. If you have been having a problem keeping your battery charged this certainly won't help.
Also since the current is higher, if you have contact points they must handle a significantly higher load. If you are not having problems keeping your battery charged, why not give them a try? What's the worst that can happen? A dead battery and a worn set of points?
They do work better with electronic ignitions!
Offline Bryan Boyle
« Reply #2 on: April 26, 2005, 03:31:48 PM »
That's what the dyna ignition set I have sitting in the box is for...:)
Yeah, I could go with the accel or dyna coils, but, figure, keep it a bit
stock appearance...
Bryan
SOHC4 #47
Morrisville PA
Offline cben750f0
« Reply #3 on: April 27, 2005, 01:17:38 AM »
no they dont just drop in, the threaded lead caps will actually hit the tank, when it is fitted, i an using VF1000 coils,here is a pic, i modified the '80 cbmount for the coils to mount the VF coils on there side and go straight down throught the frame, i am running a Dyna'S', and they creat great spark...peace
Offline cben750f0
« Reply #4 on: April 27, 2005, 01:21:04 AM »
here is another pic looking up through the frame...peace
