Author Topic: Tire Questions  (Read 855 times)
Offline Gears
Tire Questions
« on: April 24, 2010, 10:23:11 AM »
Hi Guys,
I have a couple of questions about tires for my CB750 K5, that I couldn't find an answer for through the search.
1.) What are the stock rims sizes for my bike?
I have what I think are stock rims, a 19" front and an 18" rear(based on the rubber on there), but I just wanted to know for sure.
2.) Can you mount a tire meant for a 17" rim on an 18" rim?
I really like the Avon Distanzia (http://www.avon-tyres.co.uk/motorcycle/distanzia). Okay it was pretty much love at first sight when I saw them at the NYC Motorcycle show. Problem is, the H/V rated tires only come in 17".
3.) What size Distanzia's do you think would be a good fit on my CB750?
I was leaning toward 110/80R19 front and 150/70R17 rear, both V rated.
4.) Final question. How do you choose a tube size?
Since I have spoked rims, I need to run tubes, but being younger guy, I've only ever dealt with tubeless tires, so I have no clue.
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
Re: Tire Questions
« Reply #1 on: April 24, 2010, 08:43:22 PM »
Stock tire sizes are:
front 3.25-19
rear 4.00-18
You can't run a 17" on an 18" rim
run the Distanza AM44 4.00 or 4.10 x 18 rear tire
Tube size is based on rim/tire size. The dealer will have them.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
