Author Topic: aftermarket tun signals + flasher unit  (Read 6455 times)
Offline Scott S
« on: April 25, 2010, 05:45:02 AM »
 I read through a few threads via search but most of those dealt with LED turn signals or some type of problem with the stock signals.
 I have some two-wire aftermarket turn signals coming. I'm guessing that one of the two wires on the turn signals is a ground.
 My bike ('71 CB500) has a (stock?) two prong flasher and the unused green wire on the harness.
 Will I still need the "electronic" flasher if I'm using incandescent bulbs? Do I need a 2 or 3 prong flasher?
 I see mention of the stock flasher being "mechanical". Are the flashers I can get at Pep Boys, etc., considered mechanical?
 Basically, I'm trying to run small, aftermarket turn signals with a filament type bulb. What do I need to do?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bodi
Re: aftermarket tun signals + flasher unit
« Reply #1 on: April 25, 2010, 07:31:34 AM »
Try the original flasher. The new bulb amperage might be enough for it to work.
The flasher is a mechanical device. The lamp current goes through a resistive wire wrapped around a bimetallic strip that bends when it gets hot. The current through the resistor wire heats this strip, it bends, and the bending opens a switch contact that shuts the lights off. No light = no current = no heat, so the strip cools down and bends back to where the switch closes again and the cycle repeats.
The Pep Boys etc stores have mechanical flashers and also "electronic" flashers - these as a rule have a very simple electronic timing circuit and a relay that switches the lights.
There are two terminal and three terminal flashers. Two terminal mechanical ones are sensitive to the lamp current, more current makes the flash rate faster and less makes them slower. At some low lamp amperage the flasher stops flashing, the bimetallic strip doesn't get hot enough top bend the switch contact open.
Two terminal electronic ones are relatively insensitive to lamp amperage but still need some lamp current. They all have one characteristic that I think is dangerous. Because the internal electronic timing circuit has to be powered through the two terminals, it has no power when the turn signal switch is off. When you turn the signals on, the lights must start "off" to allow the flasher's power supply to charge up (with the switching relay contact closed, there's no voltage across the two pins to operate the electronics) then it turns the lights "on for the first flash. This means you have a 1/2 second or more delay from when you flick the signal switch until the signal lights come on.
There are two kinds of three terminal flashers: ones that will work in your bike and ones that won't. The ones that won't use the third terminal for a dash light or alternating flasher output but are just like two terminal flashers in operation. The kind that works have a ground terminal and these power the electronics from the input terminal to ground: because they don't need the voltage between the input and output pins to power themselves they turn the signal lights "on" as soon as you flick the switch, flashing it to "off" in a little while to start the flashing. This type will work with any lamp current from zero up to the rated maximum number of lamps.
Just about any electronic flasher has a lamp failure sensing function. A flasher rated for four normal lamps will flash at a different rate when less that four normal lamps are connected. This can be faster or slower than the normal rate but faster is more common. Personally I like the fast flash rate with LED signals, it gets attention. If you really want the "normal" rate you can add load resistors to draw more current and "fool" the flasher, or - if you're electronically savvy - open the case and disable the lamp fail function. You just have to figure out how it works and then make it not work. This is usually not too hard, there will be a shunt wire and a voltage sensing circuit across it. You usually just have to break the circuit trace connecting the shunt to the sensing transistor or chip.
Offline nokrome
« Reply #2 on: April 25, 2010, 08:37:40 AM »
ive recently tried 3 different 3 prong "electronic/solid state" flashers to run my led signals, no luck yet.
  what am i missing? can anybody recommend one that will work
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #3 on: April 25, 2010, 02:33:46 PM »
I took the flasher out of an old wagoneer, two prong...and used it to run my carbon fiber turnsignals...no prob, but  had to do without the front running lights :-[
I like berries.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4 on: April 25, 2010, 02:52:50 PM »
I recently upgraded to a 3-prong (Tridon EP-28, $15 at Advanced Auto).  Only issue I had was the need to convert the mini-blade connectors to full quarter-inch blades.  They were sold out of the model with full blades, I guess).  This unit wired up nicely and works well even with a low battery.  It even claims to be LED compatible.
Wire the GREEN to the (-) terminal, the BLACK to the (+) terminal and the GREY to the (L) terminal.
http://superlumination.com/images/auto_bulbs/ep28_schematic_wm.jpg
More pin-outs and wiring diagrams:
http://autolumination.com/equalizers.htm
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline cb650
« Reply #5 on: April 25, 2010, 04:23:11 PM »
Stoped by napa today and they had 2 prong electronic relays.  $12
Offline Scott S
« Reply #6 on: April 26, 2010, 03:44:17 AM »
  Thanks guys. This really cleared up some question for me. I'll try the stock flasher first and see what happens. I've swapped out flashers before on other bikes with custom turns, just wasn't sure what to do in the case of the Honda.
 I'll let you know how it turns out as soon as all the parts arrive.
'71 CB500 K0
'81 Yamaha XS650
