Don't buy a kit. Clean it up like you did, put it together, do a bench sync, put it on the bike and turn on the gas. First wait to see if gas flows from the overflow tubes or float bowl gaskets. If not you are half way there. Then fire it up and see how she runs. If gas comes from the overflows you may need new needle jets and seats if they are worn to a point they will not seal. Or if they leak some guys have luck using a polish on the seats and needles, but that is down the line if you have problems. If the bike runs good then do a vacuum sync and you are good to go.
