Author Topic: Fix for loose gauges?  (Read 2264 times)
Offline Scott S
« on: May 02, 2010, 06:04:05 AM »
 I have an idea how to fix this (similar to something I've done on my Yamaha XS650's), but was wondering if there was a proven fix for loose gauges?
 It appears the rubber ring has shrunk and allows the gauges to wobble in their holder. What are some ways you guys and gals have repaired this?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Fix for loose gauges?
« Reply #2 on: May 02, 2010, 06:31:46 AM »
maybe use a syringe and squirt some acetone in there to make the rubber swell up again?
Mark Twain - Notebook, 1894
Offline cb650
« Reply #3 on: May 02, 2010, 06:48:48 AM »
My 360 was like this and I took a flat washer that fit over the "stud".
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #4 on: May 02, 2010, 07:58:54 AM »
Depending on your year and model, the foam rubber rings are probably still available from Honda. And they're not too expensive. That's how I fixed the problem on my CL350 and CB500.
Stu
MCN DTF
Offline Scott S
« Reply #5 on: May 02, 2010, 11:55:26 AM »
Bike, year, model?
 Sorry, '71 CB500.
'71 CB500 K0
'81 Yamaha XS650
« Reply #6 on: May 06, 2010, 08:41:57 AM »
Bike, year, model?
 Sorry, '71 CB500.
They're definitely still available for that bike from Honda. Part #37242-319-000. I just bought two a few months ago - around $12 each, if I remember correctly.
MCN DTF
Offline Scott S
« Reply #7 on: May 06, 2010, 12:38:03 PM »
 I pulled my gauges today and the rubber rings look like they'd been in a fire!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #8 on: May 06, 2010, 12:39:14 PM »
  I removed the remnants of the rubber rings and wrapped the gauges with some foam weather stripping I had and they tightened right up. Total cost: zero dollars.
'71 CB500 K0
'81 Yamaha XS650
« Reply #9 on: May 07, 2010, 02:47:16 AM »
Great. Let's see the finished installation.
Stu
MCN DTF
Offline Scott S
« Reply #10 on: May 07, 2010, 03:56:24 AM »
 I had a couple different sizes of foam. I used one that was actually longer than the lip of the gauge so I could compress it down and form a good seal and cushion. Just remember to put the seam at the bottom of the gauge so it's less conspicuous on the bike.
'71 CB500 K0
'81 Yamaha XS650
« Reply #11 on: May 07, 2010, 10:25:37 AM »
Nice job. That actually looks pretty close to stock.
Stu
MCN DTF
Offline cb650
« Reply #12 on: May 07, 2010, 04:14:56 PM »
Yes looks good.  Sorry I was thinking the bracket.  Shouldnt have been thinking. ;D
