Author Topic: 76 cb750 carburetor issues  (Read 1700 times)
Offline gty2k2000
« on: July 11, 2011, 05:45:19 AM »
I put the stock carburetors on my cb 750 f with the stock air box and filter clean cleaned the carbs bench since them installed them and started it and it runs but not well. It's making a gurgling piping sound every couple seconds like its running lean or rich. I am however running a kerker header so I did in stall some 110 # main jets. The carbs are clean ignition dead on. And also when I rip the throttle some times it likes to idle up real high and some times doesn't come down on its own . And when up turn all 4 mixture screws in it seems to quite it down a little bit. Do I possibly need to enlarge my idle jet to compensate for the lack of restriction of exhaust.
Offline gty2k2000
Re: 76 cb750 carburetor issues
« Reply #1 on: July 11, 2011, 01:11:52 PM »
Is there any one else out there who is running a cb750f 1 out there with a 4into1 and stock air box give me  some ideas for proper getting I live at sea level in Florida
« Last Edit: July 11, 2011, 01:31:35 PM by gty2k2000 »
bollingball
« Reply #2 on: July 11, 2011, 01:24:52 PM »
so3 netting ????
Offline BeSeeingYou
« Reply #3 on: July 11, 2011, 08:36:37 PM »
Ask Jerry Rxman Griffin.  I think he had a Kerker on his 75 F0 at one time.  He will have some insight on the jetting.  Also check for leaks on the intake boots.  If it's popping it may be a lean condition.  Your air screws should be at 1 plus or minus 3/8 turns out in stock trim so use that as the starting point.
« Last Edit: July 11, 2011, 08:41:36 PM by srust58 »
Offline gty2k2000
« Reply #4 on: July 12, 2011, 06:37:28 AM »
That's whY I set it at but it makes that gurgling piping sound at idle
Offline Holubs
« Reply #5 on: July 12, 2011, 10:45:27 AM »
I have had a Kerker on my F1 since 1980, when the exhaust was trashed in a wreck, with everything else stock.  I removed the packing from around the baffle when it rusted into the megaphone.  It appears that mine runs a little rich, I may try going to one size smaller jets next time I have the carbs off.  I did buy a Morgan CarbTune to sync my carbs.
I recently put a Pamco electronic ignition on mine, seems to start a little better when cold now.
Holubs
Toys:
2 - 1976 CB750F1 - someday projects
2018 Mustang Ecoboost Coupe
1973 Mustang Convertible - Restoration needed
Whatever happened to the old songs, like The Duke of Earl?  Whatever happened to The fu*kin' Duke of Earl? - Randy Newman
