Author Topic: Jet o-ring idea  (Read 964 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
Jet o-ring idea
« on: April 28, 2010, 12:04:51 PM »
On the several sets of carbs I've needed to rebuild, the only part of those expensive kits I've ever really needed was the o-rings for the jets. On the last set I decided to try something out. I got the waxy-est dental floss I could find. The cheap store brand seemed to work best. I wrapped the floss very tightly around the jet in the o-ring groove. I built it up to just slightly wider than the jet. Pressed in, felt just as secure as with an o-ring. I feel confident, but will report back when I hit the road if there are any problems.
Just an idea!
1974 CB550
Forever West
Offline kajtek
Re: Jet o-ring idea
« Reply #1 on: April 28, 2010, 01:43:18 PM »
will defo try this. i wasnt prepared to pay 10 pounds per carb for o rings from honda so i bought some plumbers ones and had to carefully shave them as they were too thick. i was considering trying PTFE tape next time they are out but not sure how well it does in petrol.
thanks!
ashley
1978 honda cb400f supersport
wdhewson
Re: Jet o-ring idea
« Reply #2 on: April 28, 2010, 04:21:22 PM »
The wax on floss is there as a lubricant so the floss slides more easily on the tooth surface.  It is likely a petroleum or synthetic wax (polymer), both of which will be soluble in gasoline.  As the floss loses the wax, its dimensions may shrink, and allow the main jet to draw fuel around the edges rather than through the orifice, thus upsetting mixture.  But I could be wrong, so good luck and let us know.  Don
Offline gmonkey
Re: Jet o-ring idea
« Reply #3 on: April 28, 2010, 06:15:45 PM »
And if you get the flavored floss, your exhaust will smell minty fresh.
A forum member, Kevin400F, sells an o-ring set for a good price.
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
Offline bender01
Re: Jet o-ring idea
« Reply #4 on: April 28, 2010, 07:31:49 PM »
"Kevin400F, sells an o-ring set for a good price."
 Ive used his set once.
  kthunter01@sbcglobal.net
Its a complete rubber bits for all 4 carbs. Very reasonable! Should be in FAQ section.!! But I dont think it is.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
  • The Stumped
Re: Jet o-ring idea
« Reply #5 on: April 28, 2010, 10:23:46 PM »
dang, these 500/550's?
1974 CB550
Forever West
Offline bender01
Re: Jet o-ring idea
« Reply #6 on: April 29, 2010, 06:24:05 AM »
I think he has sets for all sohcs! Tell him what you have.
75 550 K1
74 750 K4
74 750k 836 project
Good luck!
Two Tired Quote !
69modelj
Re: Jet o-ring idea
« Reply #7 on: April 29, 2010, 03:00:31 PM »
yes
