Author Topic: 78 750F Chopper/Digger  (Read 94852 times)
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
Re: 78 750F Chopper/Digger Project
« Reply #25 on: June 03, 2010, 01:43:23 PM »
looks good... im strongly considering one for mine... just gotta pick the right color...
i like that color on the block, by the way.
Offline SOHC Digger
  • I'm not an
« Reply #26 on: June 08, 2010, 03:50:01 PM »
Disassembled, cleaned, inspected, and reassembled the oil pump today.  I installed it and put the freshly painted oil pan on as well.  Gotta do something with that drain plug, though.
Carlingas
« Reply #27 on: August 28, 2010, 10:27:43 AM »
Fantastic build..anything new brewing? :)
Offline SOHC Digger
  • I'm not an
« Reply #28 on: August 28, 2010, 10:17:38 PM »
I have a bit of painting to do on the other engine parts and I just finally got my seal kit.  The engine rebuild should continue once the weather cools a bit.  I still have to clean the fuel tank as it's got some rust inside.  After that, I'm looking for a hex or octagon oil tank and the rest is pretty much just waiting to be assembled.  This summer has been busier than I thought and unfortunately this project has been on the back burner... but not for long.
wvhardtail
« Reply #29 on: August 30, 2010, 05:41:45 PM »
Looking sweet! Can't wait to see how this one turns out. I am in the middle of a build myself so I love seeing what other people are doing.
Offline SOHC Digger
  • I'm not an
« Reply #30 on: September 14, 2010, 03:47:00 PM »
Pics coming soon!  Cleaned my pistons with Simple Green; I can't believe how well it worked getting carbon off.  Started disassembling my head and the valves are cleaning up nicely too.  Clutch is back in, shift linkage all together (I hate trying to remember how those springs go), installed some seals, painted most of the rest of the parts, and honed my cylinders.
Offline SOHC Digger
  • I'm not an
« Reply #31 on: September 16, 2010, 11:17:06 PM »
Here's some pics.  The pistons cleaned up with Simple Green pretty easily.  I love that stuff!  Installed the pistons yesterday.  Disassembled my head today.  It's going off for bead blasting after I clean it tomorrow.
Offline cheapride
  • Work Hard Play Hard
« Reply #32 on: September 17, 2010, 10:46:03 AM »
Hey man nice job on the build.  I just got myself a 78 F as well with the same paint as yours.  Are you going to do anything special to the head?  Im taking notes too ;D
Brent
1978 cb750f Supersport
Offline SOHC Digger
  • I'm not an
« Reply #33 on: September 17, 2010, 08:09:40 PM »
Head is not getting any special treatment other than a thorough cleaning and new seals.  When the top end goes out, whenever that is, then I will go to an 836 kit and some serious head porting.  Right now though, I am going to see how it performs stock.  The top end is easy enough to redo.
Offline SOHC Digger
  • I'm not an
« Reply #34 on: September 20, 2010, 10:59:58 PM »
Put my cylinder block on tonight.  Went smoother that I had anticipated.  The rings cooperated nicely.
Offline sky56
  • would you like to see my
  • Chgo winters can suck but great time to wrench
« Reply #35 on: September 21, 2010, 08:33:36 AM »
Very cool so far man. Im doing a winter build myself and live in the city. you ever heard of half fast chicago?
Many honda bikes and a lifted 75 Chevy K5
Offline SOHC Digger
  • I'm not an
« Reply #36 on: September 21, 2010, 10:43:30 AM »
No I have not.  What is Half Fast Chicago?
Offline SOHC Digger
  • I'm not an
« Reply #37 on: September 24, 2010, 03:56:40 PM »
Just some more pics.  I have my head out being blasted by Jeff from work who has done all my other blasting work.  Will be making a valve spring compressor while I wait because the Advance Auto Rent-A-Tool POS sucked while removing my valves.
Offline SOHC Digger
  • I'm not an
« Reply #38 on: October 21, 2010, 05:51:41 PM »
Got my head back from Jeff yesterday.  Amazed again with his work.  I can't stress what a reasonable guy he is.  I had to talk him into charging me at least $30.  He wanted to charge me $25 for doing the head and valves and I told him that was way too cheap.  He said "Fine, gimmie $30."  Pics will be up soon.  He got ALL the carbon, paint, and head gasket material off of it.
So, now I just have to lap the valves, reassemble, and paint it.
Offline SOHC Digger
  • I'm not an
« Reply #39 on: October 22, 2010, 07:42:51 AM »
Tapped all the hoes in my head and measured valve guide clearance.  Intakes are good, exhausts are trashed.  Son of a ... Looks like a set of valve guides will be coming my way.  Mocked up the rest of the top end just to see how it will look.
Offline Flying J
« Reply #40 on: October 22, 2010, 09:24:18 AM »
YOu go boy! Tap them hoes.  ;D
Offline HedNut
  • Underwater Basket Weaving
« Reply #41 on: October 22, 2010, 09:29:19 AM »
A couple pictures back...you're cases looked pink.... I was like.....alright' cool...  But it's actually red...which is a lot cooler! ahha   Looks GREAT MAN!!  You're on your way to a super-slick bike!
Offline SOHC Digger
  • I'm not an
« Reply #42 on: October 22, 2010, 10:29:14 AM »
HAHA!  Didn't notice that until now!
Offline SOHC Digger
  • I'm not an
« Reply #43 on: October 31, 2010, 06:24:57 PM »
Gas tank has been sitting for about 15 hours with phosphoric acid solution inside of it.  Amazing results so far!  Probably give it another 12 hours or so and then turn it over so the top end gets the rust removed well.
Offline SOHC Digger
  • I'm not an
« Reply #44 on: November 02, 2010, 05:43:53 PM »
Tank is looking GREAT on the inside now!!!  I let the tank sit for 24 hours with about 50% water, 50% Phosphoric Acid and then flipped it upside down for another 24.  Every spot of rust is gone!!!  I rinsed the tank really well with hot water and then coated the inside with some oil to keep any rusting from occuring before it gets fuel in it.  Follow these threads for a quick and easy method to renew your tank too!!!
http://forums.sohc4.net/index.php?topic=21464.0
Quote from: Terry in Australia on May 05, 2007, 06:14:25 am
Steel wool (or even scotchbrite pads) will scratch chrome, and it's a lot of hard work. Get some phosphoric acid and add water at 5 parts water to 1 part acid and dip the rims, fenders, grab rails, blinker stalks, exhaust pipes, handlebars, chain guards, seat bases etc etc in the solution for a few minutes then just pull it out and rinse with clean water, and you'll think it just rolled off the factory floor, no scrubbing or polishing required! Cheers, Terry. ;D
http://forums.sohc4.net/index.php?topic=31053.0
Quote from: eurban on February 22, 2008, 07:40:47 am
The Home Depot's here in MD are now carrying phosphoric acid in their paint stripping section.  Product is called "Prep and Etch." It is a gentler, more forgiving product than muriatic acid that takes overnight to work but leaves a rust inhibiting coating on the metal.
http://forums.sohc4.net/index.php?topic=31970.0
Quote from: Roach Carver on March 15, 2008, 04:45:57 pm
did this, this weekend. Watch out for flash rusting. I read up on this a while back and it seems that the best acid to use is phosphoric acid as it will remove the rust while leaving the metal in a state that is somewhat inhibitive to oxidatation/rusting. I have done some small parts in phosphoric acid and noted no flash rusting.
Offline SOHC Digger
  • I'm not an
« Reply #45 on: November 11, 2010, 02:18:53 PM »
Got my valve guides from Cycle X along with the Triangle headlight on their website.  Installed the guides, lapped the valves, reassembled the head, and painted it.  I also just won this oil tank on ebay so we'll try that out.
Offline SOHC Digger
  • I'm not an
« Reply #46 on: November 18, 2010, 01:35:26 PM »
Picked this seat up off Ebay for $52!!!  Now just have to find the matching pillion!
Offline theofam
  • I'm cold, give me a
  • Suffering from MDD - Mechanical Deficit Disorder
« Reply #47 on: November 18, 2010, 05:29:15 PM »
Digger, I just came across your build, and man, is it SWEET!  I didn't read how you scored the frame.  Another craigslist score?
I love the HEMI orange, too.  The motor looks way nice.
Offline SOHC Digger
  • I'm not an
« Reply #48 on: November 18, 2010, 08:25:55 PM »
Thanks!  Yeah, the frame is a CL score.  Supposedly it may be a Corbin & Gentry, but I cannot find any identifying marks on it.
Offline theofam
« Reply #49 on: November 18, 2010, 08:55:07 PM »
I don't even know what that means. You could call it Martha & Stewart, and I'd still think it looks kick $&@!
