I was having a voltage drop at the coils. Used to have below 10V at the coils, something like 9.7, with a fully charged battery of 12.9V. Tracing the voltage drop, I found out that the kill switch robbed more than 3 Volts. I cleaned every electrical connector on the bike and used dielectric grease everywhere, I dismantled the kill switch to clean it and I still got a substantial voltage drop. So I did the «car solenoid» modification to temporarily fix that problem. I plan on getting a new kill switch down the line to replace the present one.
Now, with the mod, when every thing is at off (key and kill switch) I get say 12.9V at the battery.
If I turn the key on with the kill switch at off and with the headlight at off, I get 12.6 volts.
Then, when I turn the kill switch to «run», I get 12.4V at the battery and 12.3V at the coil.
These numbers are kind of approximate since the Voltage goes down when the circuit is powered. The numbers are the highest numbers I get before they go down.
I have yet to test what voltage I get at the coils while the engine is running. I'll check that tomorrow.
The jets have not been drilled. I got them a few years back when I was trying to fix this same problem. They are clearly stamped with their #40 and 75#.
Keep em coming!
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
Simon
