Author Topic: Fuel addatives..  (Read 4954 times)
Offline toycollector10
Fuel addatives..
« on: January 29, 2006, 12:07:59 AM »
I couldn't find anything in the FAQ's so here goes. I always put a thimble-full of two-stroke oil in a full gas tank, a previous poster said this would line the pipes with oil and prevent rust. I'm guessing it also lubricates the intake valve stems, (as per HondaMans post on Acetone) and the slides etc.
What about addatives that "clean your carburetors, removed deposits and improve running" etc?  Any good?
I am also using a product called 'Valvmaster' which apparently lubricates the valve seats, a job previously done by lead which has now been removed from fuel. Funnily enough the product is simply kerosene or some variant of kerosene.  Any comments?
Thanks, TC
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
Jim Shea
Re: Fuel addatives..
« Reply #1 on: January 29, 2006, 02:13:09 AM »
I have wondered how an engine that used to run on leaded, works OK wiith unleaded? or would a po have to have done something?
I had a Mini that had not been touched and was advised only to run it on leaded!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: January 29, 2006, 03:22:22 AM »
This has come up several times. Actually, the old Hondas are fine with unleaded fuel. The valves/seats are hardened, Stellite I believe it is called. Try a search, should find lots on this.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: January 29, 2006, 04:01:09 AM »
Honda foresaw the coming of unleaded fuel, so they made all the sohc4's compatible with it.
Jim Shea
« Reply #4 on: January 29, 2006, 04:04:07 AM »
Thanks. It's a shame British Leyland didn't do the same with the Mini??
Offline cb650
« Reply #5 on: January 29, 2006, 07:58:58 AM »
Most all alum heads have hardened seats.
            Terry
Offline jaknight
  • ....Round Town Ride......
« Reply #6 on: January 29, 2006, 08:19:30 AM »
Hey toycollector10,
   In my particular case, I have found that the best gas additive for me has been a product called SeaFoam.  It is used considerably by marine boats and any gasoline engine users for removing and preventing rust.  When poured straight into the gas tank, it will clean fuel injectors and carb fuel jets, removes all moisture.  You can put it in your crankcase oil and it will clean dirty parts and increases RPM vacuum and compression.
   I don't know if it is available in your area, but it is well worth searching for.  It has been made since the late 1940s.  It Removed rust from my gas tank with the first use, and has kept it clean since then.  It comes in a 16oz. can and you use like about 3 to 4 ounces on first application, but you can go up to 8 oz. on first application if you want to.  It has beat anything else I have ever tried.
   ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline dusterdude
« Reply #7 on: January 29, 2006, 08:23:27 AM »
Hey toycollector10,
good stuff
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cb650
« Reply #8 on: January 29, 2006, 10:00:46 AM »
Sea foam is at yami dealers right?
           Terry
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: January 29, 2006, 10:02:44 AM »
           Terry
Pep Boys and AutoZone usually has it.
eldar
« Reply #10 on: January 29, 2006, 06:11:20 PM »
Another vote for seafoam. You will not likely find it at many dealers however. They want you to buy the expensive stuff that does not work any better.
Offline mrbreeze
  • Not your average
« Reply #11 on: January 29, 2006, 10:10:44 PM »
I got mine at Napa...about $7 a can.Good stuff.
MEMBER # 257
Offline DrMark
« Reply #12 on: January 30, 2006, 10:21:51 AM »
SeaFoam has my vote. Many uses in fuel and oil. Found at Blaines Farm & Fleet here in the midwest region of the USA. Used by lots of farmers. Usually on sale for $5.50 a can
1978 CB550K
1983 CB650SC Nighthawk
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #13 on: January 30, 2006, 10:23:52 AM »
SeaFoam, elixir of the gods.  I'm on my second tank with it, and either she really likes to run in 40 degree weather or this stuff works.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
« Reply #14 on: February 07, 2006, 08:18:43 PM »
Thanks guys, I couldn't find any SeaFoam so brought some Fuel-Up, which claimed to do pretty much the same. I know my bike doesn't smoke because I have followed a friend who was riding it and giving it hell. But after adding the Fuel-Up I was told it had a lot of black smoke comming out (not blue-black) under hard acceleration. My best guess is that the product is clearing a lot of crap out of the combustion chamber. Well, I hope thats what is happening.   :-\
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
Jim Shea
« Reply #15 on: February 08, 2006, 01:33:16 AM »
I wonder! let us know how it goes?
« Reply #16 on: February 08, 2006, 02:54:18 AM »
Will do Jim, "stand by your bed"..As we used to be told  in the Air Force..i.e stand-by
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
Offline scott_cb650
« Reply #17 on: February 08, 2006, 09:51:05 AM »
Go here to find a dealer near you: http://www.seafoamsales.com/buy.htm
Why worry about tomorrow for tomorrow has enough troubles of it's own.
« Reply #18 on: February 08, 2006, 10:30:18 AM »
Black smoke from internal combustion engine exhaust is often referred to as "Unburned Hydrocarbons".  When these are found in the air we breathe, it's called pollution.
Pollution was a Hot Topic in the '70s and '80s.  I remember the air in the Los Angeles basin being referred to as "Chewy".  Then the environazis gained power and...
Well, now we can't buy new bikes like the SOHC4s.  But, somehow Harley survives. ???  Are these immune to pollution control? ???
This message brought to you by...  Scrambled Ramble Productions, Inc.
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #19 on: February 08, 2006, 10:34:25 AM »
How will running a rich mix or seafoam affect the engine? I'ved used it, but in the prescribed 1 ounce per gallon of fuel.  I see posts here that talk about using half a can per tank and that's around twice the recommended "dose".  I figure it'll clean better, but does it affect the engine negatively?
« Reply #20 on: February 08, 2006, 10:34:55 AM »
Good question...
eldar
« Reply #21 on: February 08, 2006, 10:43:40 AM »
Well a can is 16 oz. and the average 750 tank is 5 - 6 gallons. So a half can is only a little stronger than 1oz per gallon. Not much of a big deal really since we have no o2 sensors or any electronic crap to mess up.
Offline Bodi
« Reply #22 on: February 08, 2006, 10:58:30 AM »
I like to add a shot of Castrol R to the tank. I don't think it does any good or bad, I just love the smell of the exhaust.
swamprat
« Reply #23 on: February 08, 2006, 02:24:18 PM »
There is an excellent article on fuel and oil additives in the Dec/Jan '06 issue of RoadBike.  Pretty much says all are "Snake Oil".
eldar
« Reply #24 on: February 08, 2006, 02:43:39 PM »
Problem with alot of those articles is that it is onlly short-term testing done with meticulosly maintained bikes.
Seafoam has been around for years and tested by many here on this site alone. ALways with good results. We are garage mechanics who, in many cases, are smarter and know more about bikes than the editors of these magazines.
While some are most certainly bad products or do nothing, there are a lot that are actually very good. I have even used seafoam in new vehicles and it in almost every case has helped increase gas mileage for a few tanks of gas. Power is also increased in some cases.
If there is a question about a product, never listen to a magazine that barely tests anything. Listen to the actual hands-on people that have used things a long time, you will almost never be steered wrong.
