Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
where should I begin to look for flat slides for the CB750s mike? got a part number by chance?
Quote from: midnight08 on May 03, 2010, 05:44:36 AMwhere should I begin to look for flat slides for the CB750s mike? got a part number by chance? http://www.motorcyclecarbs.com/Mikuni_TMR_Carburetors_Comple_C1819.cfm The price is probably lees because of the euro being in the toliet.
Is that a sync port just in the head on #4 ?
Quote from: MRieck on May 03, 2010, 09:41:08 AMQuote from: midnight08 on May 03, 2010, 05:44:36 AMwhere should I begin to look for flat slides for the CB750s mike? got a part number by chance? http://www.motorcyclecarbs.com/Mikuni_TMR_Carburetors_Comple_C1819.cfm The price is probably lees because of the euro being in the toliet.They sure are sweet!But at current rates, that 2,295 euros becomes $2842.12 USD!!!
I always wondered if the early GSXR 750 flatslides could be made to fit the Honda and if they would work ok..... i think they were 29'sMick
Hmmmmm, interesting, i wonder what mods if any he did to run them, i read somewhere the venturi is 33mm on those carbs....Mick
Quote from: retro rocket on June 05, 2010, 06:00:06 PMHmmmmm, interesting, i wonder what mods if any he did to run them, i read somewhere the venturi is 33mm on those carbs....Mick He said they were a #$%* to fit onto the insulators. The TMR adaptors are perfect. The throttle return spring is sinfully easy on the TMR's.
Just priced Weber DCOEs at $400 a pop...
